Ufopolitics
Wow!!, I do love that structure Rakarskiy!!
Where can I buy it?
Cheers
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
ariovaldo
Quote from: Ufopolitics on May 06, 2022, 11:26:23 AM
Hello Ariovaldo,
Let me see if I understand correctly what you are doing on that video:
You are feeding (Input) with single-phase AC 110-120V from your wall, plus a capacitor, the 3 phase motor stator, on just one phase, one set of coils...correct?
Then collecting on the center coil on iron.
Thanks
Ufopolitics
Yes. I have done so many other configurations, and nothing has worked as I thought.
Ufopolitics
Quote from: rakarskiy on May 06, 2022, 12:43:27 PM
https://ru.made-in-china.com/co_szjiarun/product_Rotor-Stator-of-Silicon-Sheet-Material_riurusneg.html
Thanks,
But is it Laminated Steel?
Plus, the inner piece do not have openings?
It is sealed on the outer...
And then I have to buy 100 pieces?!!
Not planning to market this...hahahaha
Thanks anyways, it is good to know!!
Cheers
Ufopolitics
―Leonardo da Vinci
pix
Hello Ariovaldo,
You are feeding (Input) with single phase AC 110-120V from your wall, plus a capacitor, the 3 phase motor stator, on just one phase, one set of coils...correct?
Then collecting on the center coil on iron...right?
Thanks
Ufopolitics
May be 2 options to get rotating magnetic field in 3 phase motor out of 1 phase supply:
1. Yes, you can feed 3 phase motor from 1 phase with use of capacitor to make a phase shift. Already tried this and it works. See attached.
2. I see also on the switchboard rack a driver. You can have driver feed from 1 phase and with 3 phase output. Very common for smaller motors.
Using only one set of coils on the stator and feeding it with 1 phase supply will not rotate magnetic field.
Cheers,
Pix
