Capture Radiant Energy via Coils
Started by archon79, January 21, 2007, 04:19:26 AM
archon79
(The following text taken from 'The Free Energy Secrets of Cold Electricity' by Peter A Lindemann and looks likely to be the basis of the SM TPU)
Tesla accidentally discovered an electrostatic "super-charging" effect while trying to verify Hertz' discovery of electro-magnetic waves. After hundreds of experiments, he learned how to control and maximize this phenomenon. This led him to the discovery that electricity is made up of different components, that can be separated from each other, and that a pure, gaseous etheric energy can be fractionated away from
the flow of electrons in a circuit designed to produce short duration, unidirectional impulses. When all the conditions were right, this gaseous, etheric energy would manifest itself as a spatially distributed voltage that would radiate away from the electrical circuit as a "light-like ray" that could charge other surfaces within the field.
From now on, I would like to refer to this phenomenon as "The Electro-Radiant Event" and summarize its characteristics as follows:
1. The Electro-Radiant Event is produced when a high-voltage, direct
   current is discharged across a spark gap and interrupted abruptly
   before any reversals of current can occur.
2. This effect is greatly increased when the source of direct current is
   a charged capacitor.
3. The Electro-Radiant Event leaves wires and other circuit
  components perpendicular to the flow of current.
4. The Electro-Radiant Event produces a spatially distributed voltage
   that can be thousands of times higher than the initial spark
   discharge voltage.
5. It propagates instantaneously as a longitudinal, electrostatic "light-
   like ray" that behaves similarly to an incompressible gas under
   pressure.
6. Electro-Radiant effects are solely characterized by impulse duration
   and voltage drop in the spark gap.
7. Electro-Radiant effects penetrate all materials and create
  ?electronic responses? in metals like copper and silver. In this case,
  ?electronic responses? means that an electrical charge will build up
  on copper surfaces exposed to Electro-Radiant emissions.
8. Electro-Radiant impulses shorter than 100 microseconds are
  completely safe to handle and will not cause shock or harm.
9. Electro-Radiant impulses shorter than 100 nanoseconds are cold
   and easily cause lighting effects in vacuum globes.
The "Electro-Radiant Event" is essentially the "gain mechanism" that Tesla discovered that is the basis of his Magnifying Transmitter. It is the foundation of his claim that he was able to create more energy in his output than it took to initiate it in his input.
http://satanicsingles.com/library/The_Free_Energy_Secrets_of_Cold_Electricity.pdf
archon79
(The following is a message from Steve Mark to Mannix, showing that TAO was on the right track about the TPU, and also confirming the above post)
I want to mention about something I read on the site. A person named TAO wrote this to you a while back:
>As a gesture of good faith towards you and the rest I'll throw out some insights...
Lets talk about the 'kick.' When the old Edison DC generators were turned on, back in the day, they released this 'kick' and killed many workers in the process. A man by the name of Tesla had seen this. He wondered how and why this 'kick' would occur. So he experimented with wire and disruptive discharges from capacitors. It was found by him that this kick could be made so powerful that it could explode wires instantly. This kick came out of the wires perpendicularly. He discharged capacitors into stout wire and through a spark gap. The key to the kick's strength and appearance was in how fast Tesla discharged the capacitors into the spark gap AND how fast Tesla STOPPED the flow of current AT the spark gap. Tesla used all types of devices to stop this flow of current, magnets, a flame, counter-rotating engines. His goals were to get the time in which the discharge is STOPPED to be much quicker. As Tesla did this he found that the perpendicular radiations, the ones from the wires, caused electrical effects to appear in wires and other copper/metal materials near the STOPPED current/discharge. These electrical effects could be made to create electrons on other wires and copper around his STOPPED current/discharge wire.
So, based on those things, lets look at the Mark device. Lets say Steven put one big stout cable around or in the rings,and all around these he had many many windings. Now, if Steven put into that stout cable a current and before the current could get to the end of the wire, he stopped it's flow abruptly, then perpendicular radiations (the KICKS), the same Tesla observed, would appear and spread from this stout cable, this would cause Tesla'a copper charging effect, which would hit all the other wires in Steven's coils. Now, if Steven wired the coils right and stopped the discharge of the current through the coils he would be able to extract a lot of extra energy from the tap points on the coils. This is basically how Tesla's magnifying transmitter works.
Capacitors discharged ABRUPTLY into a wire, then the current flow is stopped ABRUPTLY
before the current makes it to the end of the wire, and this KICK comes out of the wires
perpendicularly. This KICK would then charge copper with electrons(hot electricity) or their opposites(cold electricity). It just depends on how you setup the device.
So, I would say that Steven's KICKS have a direct relationship to Tesla's Magnifying Transmitter, its REAL operation.<
So Lindsay, this guy definitely has the secret. I do not know if he will be able to duplicate power generation, but he does have the secret.
Do you think he knows it?
The only part he doesn't have any idea about is that by starting the oscillation you cause the current to flow in the collector which causes the magnification of the process within the collector which will ultimately produce the greater voltage and power in usable amounts during operation.
Lindsay, it is so VERY hard to describe things with words!
Sincerely, SM
archon79
Attached to this post is the Magnetic Power patent for a solid state free energy torroid. It is very interesting but this point is made.
QuoteUse of a resonant circuit, particularly with inclusion of a capacitor as suggested, facilitates recirculation of energy within the input circuit, generally producing efficient excitation and a reduction of required input power as loads are applied.
And TAO mentions here..
QuoteCapacitors discharged ABRUPTLY into a wire, then the current flow is stopped ABRUPTLY before the current makes it to the end of the wire, and this KICK comes out of the wires perpendicularly.
And Lindemann
Quote1. The Electro-Radiant Event is produced when a high-voltage, direct
Just bulding a coil and pulsing frequency through it and measuring output alone is not going to achieve anything. The discharging of a capacitor phenomenon seems to be very important to these devices.
AhuraMazda
It appears there may be two more ingredients needed to make MPI's patent work: Superconductivity and perhaps Plasma.
Read the last part of the following link:
http://www.zpenergy.com/modules.php?name=News&file=article&sid=1357
AM
archon79
The operation of the device would be a small battery to start a control circuit which creates the short pulse and radiant effect, and then an oscillation which creates usable electricity.
QuoteThe only part he doesn't have any idea about is that by starting the oscillation you cause the current to flow in the collector which causes the magnification of the process within the collector which will ultimately produce the greater voltage and power in usable amounts during operation.
Now the question really has to be asked, which approach did SM use to create the oscillation ?
Is the oscillation caused by combining frequencies and hitting some kind of harmonic? Or is it something to do with spinning/expanding/collapsing magnetic fields?
This evidence points to the later, but the main effort of this board has been the former.
I urge you to read the Magnetic Power patent. It really does have some great information on this very subject.
