General coil winding question
Started by captainpecan, May 20, 2022, 10:34:01 AM
captainpecan
Let me rephrase it. My original question of if it would divide by 4 instead of just two was answered but then a new one come up from the response.
If we could double the copper, by doubling the turns, without changing the resistance, would we still double the output flux? Then using a parallel wind, we can do just that. Half the coil with 2 strands to cut the resistance in half. Then double all the copper and turns to bring it back to the original resistance except now its double the copper and double the turns, with the same power. I'm not saying it works that way, I am just asking because it seems it would.
Cadman
Quote from: captainpecan on May 20, 2022, 04:42:37 PM
Thank you for the response. Exactly what I thought, except maybe your citation at the end. I was under the impression that if a coil had 200 turns at 12v 100ma it would have half the flux as one with 400 turns at 12v 100ma, even though it is exactly same power draw. Am I incorrect? I thought with the equation, if all variables stay the same except for N, the number of turns, wouldn't just increasing the turns increase the flux? Not arguing by any means, just trying to understand. Like if you ran the same current into 1 turn there should be a way less strong field than 500 turns for the same power. But maybe I am wrong? It sounds like you are saying as long as the voltage amd current is the same, the turns can increase or decrease but the flux will not change?
Bi told it like it is.
The amount of flux is directly proportional to the amps per turn of wire.
All else being equal, 200 turns @ 100ma is half the flux of 400 turns @ 100ma.
It's the amp turns that matter.
captainpecan
Quote from: Cadman on May 21, 2022, 02:22:29 PM
Thats what I thought. Doubling the copper and the turns for the same current, does double the flux. So I do understand it correctly. Thank you very much for clearing it up.
bistander
Quote from: captainpecan on May 21, 2022, 05:01:12 PM
Actually it doubles the mmf, not necessarily the flux. That depends on the material BvsH characteristic and the shape of the core.
bi
