Thanks to ALL for your help!!
The Real No Lenz Generator (opposite Lenz Effect) Watch Video
Started by JackJohn, June 17, 2022, 05:39:53 AM
JackJohn
Sorry I deleted the video, see you later in my next project with more detailed measurements, more little Profesional look and the use of English
rakarskiy
You are misinterpreting Lenz's Rule! The magnetic flux of a coil without a core and the magnetic flux of a coil with a core are two different things.
It is enough for you to focus the magnetic flux to the center of the coil and the magnetic fluxes of the external field and the coil will coincide.
This entry of the EMF equation refers to the eddy magnetic field and the eddy EMF around the conductor.
It can be written in the following expressions: E=-Фi/dt or Фm/dt = -E
where:
E - EMF around the conductor, measured in volts
Фm - magnetic flux of the external field [Ф = BS]
Фi- eddy magnetic flux of the conductor under current  [Ф = LI]
PS:
If you understand these simple concepts of direction vectors, you'll understand how things really work.
In this thread, one of my posts was deleted (although the links of other participants to it remained)!
https://overunity.com/18075/self-poweredgenerators-motors-part-34/msg527893/topicseen/#new
You can read my explanation here at the end of the article:
https://rakatskiy.blogspot.com/2018/12/au5389086.html
JackJohn
Quote from: rakarskiy on June 19, 2022, 03:06:10 AM
thank you for your explanation, so far I have interpreted the Lenz Effect on generators and motors to be limited to the phenomena caused by them. and as we know the Lenz Effect appears in the braking that occurs in the generator (decreasing speed) when the condition is connected to the load. which ultimately results in an increase in the current strength of the driving motor. and this is the main reason for Device failure to reach COP > 1
rakarskiy
Quote from: JackJohn on June 19, 2022, 03:39:19 AM
In traditional generators, the current strength in the phase wire leads to the formation of an enhanced stator magnetic field, which will eventually lead to magnetic blocking - the magnetic system (rotor-stator).
But there will be no electromagnetic induction itself without Lenz's rule. It is necessary to work not with "Lenz", but with the work of magnetic circuits for closing and opening, at a certain point in time.
JackJohn
Quote from: rakarskiy on June 19, 2022, 03:55:18 AM
"But there will be no electromagnetic induction itself without Lenz's rule. It is necessary to work not with "Lenz", but with the work of magnetic circuits for closing and opening, at a certain point in time."
I totally agree with you about this, I also believe in the induction process must follow Lenz's rules. So it is very clear that there is no process of removing the Lenz but avoiding the braking effect caused by the Lenz Effect is the most important thing. regarding what you said that "magnetic circuit work to close and open, at a certain point in time" it's just one technique just like the Ecklin Brown Generator which utilizes a magnetic field opening and closing system and I have a different technique about it
