NEW FED PROJECT (QEG LOOK LIKE STATOR)
Started by JackJohn, June 26, 2022, 06:58:01 AM
JackJohn
A little of my imagination for today
The strength of the braking due to the Lenz Effect depends on the "big or small amount of power drawn from the generator output".
example :
Induction on the generator rotor produces 12V 1A (12W) power and you give the generator output (Led 3W) then you can see that the amperage of the driving motor does not show a change / does not increase, it will be different if you use (Led 6W to 12W) then braking due to Lenz The effect can be directly seen in increasing the amperage of the driving motor.
So the key is:
Drive motors as efficiently as possible (BLDC, Brushed DC etc.)
make a generator that is capable of producing 10X the output power when compared to the power needed by the driving motor at no load (this seems crazy) not even if you know the Flywheel mechanism, play the number of wires, play the number of magnetic poles, take advantage of good bearings etc.
Give a load of only 30 to 40% because that is more to meet the power needed by the motor that drives and the rest is up to you.
"Do not rob the power out of the generator (take all of it), just accept what is given (In Java Language " Nrimo Ing Pndhum") Then you will not feel the resistance from the generator which will make the power of the driving motor Ampere supply increase" let the device (motor generator) work like no load
JackJohn
JackJohn
Another test speed Video with Ampere measurements
24VDC (0.2 ~0.3A) Power supply . Very High speed 10K Up RPM Check it out
"Pay attention to the effect of inertia produced by the flywheel system with a small ratio on the rotor and a large one on the motor, when staring up power consumption in amperes, it was more than 1 Amp but look when the speed is met, the flywheel repays the motor by returning the inertia so that the motor rotates like without load, even lighter".
With a slightly wider gap between the magnet and the iron core of the generator coil, the Brakking due to the lens effect can be avoided. It's actually the same as playing the mechanical version of resonance (motor generator)
This Link Video >>>  https://dai.ly/x8cbq6g
JackJohn
JackJohn
Small Update not test video (don't need to watch) 😂 😂 😂
the planning is single coil working as pulse dc motor and AC generator + Back EMF Trapping (DC)
if look at schema is very simple right  ;D ;D ;D
but actually it's not as simple as it looks, because on the JackJohn coil I played with the number of turns, the resistance value of the wire and also  special position of the primary and secondary Coil wires. will this be successful in producing more power than the power required for the pulse dc supply? no body Know the result
still can't be answered right now, please look forward to the continuation of the process of making this device
https://dai.ly/x8chgzd
