Water Injected Engine?
Started by TommeyReed, July 05, 2022, 08:34:30 PM
TommeyReed
Hello All,
I have been looking into a basic engine design with 50:1 compression ratio for a experimental water injected engine.
The temperature could reach 2000+deg and injected water to created superheated steam with a expansions 1600 times the volume. and pressure over 2000 psi.
If 400c can create 100bar(1450.38psi) of steam wouldn't it be much higher if it is 1000c?
This is just a theory at this time, getting the compression would be much easier with the help of hydraulics.
Tom
aussiebattler
Sounds a bit dangerous Tommey
Paul-R
What is the source of the heat required?
kolbacict
And where did you lose the heat of vaporization?
It's very big for  water.
p.s. To write correctly "It's very big for  water" or "It's very big for the water" ? :-[
Paul-R
We don't have  much to go on. An estimated thermodynamic P/V diagram would be useful.
