Maybe possible idea for duplicating effect of Holcomb and others
Started by citfta, August 19, 2022, 04:00:12 PM
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
Quote from: bistander on August 20, 2022, 09:52:30 AM
Think about that 'inner' coil, the field coil which is concentric to the shaft or axis of rotation. Actually, in its normal operation, it does not need to rotate. It would work just the same in the alternator if held stationary while the steel claw rotated. In standard alternator operation, it, the field coil, produces the RMF. But that process being reversible, would simply induce DC in the coil.
bi
Hello Bistander,
Yes, I agree with you on the above...and that was my point, originally, when I have said that the Magnetic Field actually does not move at all in this type of Automotive Alternators...
What actually "simulates" a rotation of the field are the alternated NSNSNS claws spinning...plus, the way you have put it is perfectly well explained...yes, actually the coil did not need to rotate, just the claws.
However, look at it from "the other angle"...projecting a rotating alternated field to the now stationary claws...imagine it in your mind.
If it is done orderly alternated, it will "flash" upper and lower coil caps with NSNSNS...or viewing the way you like, it will alternate the B-Field Vector up and down related (parallel) to shaft direction.
Do you agree?
And do not worry...it would be exclusively up to Citfta if He wants me to delete you or not...hahaha
But, yes, definitively I also find it as a very interesting experiment.
Ufopolitics
―Leonardo da Vinci
bistander
If the stator is excited to produce the RMF, and the claws are stationary, the concentric coil sees AC. If the claws rotate at synchronous frequency, the concentric coil sees DC.
bi
Ufopolitics
Quote from: bistander on August 20, 2022, 11:05:17 AM
bi
Yes...agree.
Claws would be stationary, as rotor, as concentric coil...according to Citfta proposal.
So, through Rotor slip rings it will collect AC...and IMO, it will be pretty fast changes (short angles) from claw to claw angle.
Which is actually good, as the Generator side Rotor-Motor, would not need to go that fast (or 3600 RPM's)
Ufopolitics
―Leonardo da Vinci
bistander
But there is no moving magnetic field cutting the coil, which is the intent, or so I thought.
bi
