Maybe possible idea for duplicating effect of Holcomb and others
Started by citfta, August 19, 2022, 04:00:12 PM
citfta
Quote from: kolbacict on August 29, 2022, 03:14:46 PM
And to me for some reason, no power is removed from the collector rings of the Lundel rotor .
When a three-phase voltage is applied to the stator.
And also the rotor does not want to rotate when selling direct current to the rotor. >:( :(
Do you have a scope so you can show us what signals you have on the 3 phase wires?
kolbacict
Quote from: citfta on August 29, 2022, 03:20:12 PM
There are about five volts on the Lundell rotor (brushes). Without load.
There is practically no current.
It does not depend on the position of the rotor.
Jimboot
Quote from: Ufopolitics on August 29, 2022, 01:43:34 PM
Hey Jim,
Man, that Alternator is a beast!!...on what vehicle that goes on?
I see that it has two strands of wire per phase...I figure you should have like 0.4-.0.3 Ohms resistance there!!
Reason why it blew one of your FETs...
I would try with just one strand on each phase.
I was checking out your FETs (IRF1405) and they have even higher spec's (capacity) than the IRF3205...So, when I look at your alternator image, then I  realized where the issue was.
You meant, that when you rotate the Stator (Magnetic Field) "it changed the waveform of the Rotor",  reading from the brushes, I assume?
Look at my alternators below...not even near the gauge size you have, plus you have 2 strands!!
Ufopolitics
Thanks UFO - the double strand surprised me. This is my first alternator tear down.  I can measure the 2ohm rotor directly on the coil connections. Brushes removed. So I could see at least transformer action before it blew.
kolbacict
this little BLDC is working  by turkey technology.  :)
https://youtube.com/shorts/u-SSQF_LIIM?feature=share
speed and torque depend on the supply voltage.
Ufopolitics
Quote from: kolbacict on September 01, 2022, 06:11:53 AM
That is wonderful Kolbacict!!
It tell us that this Turkish Tech ESC works on any level!!
Can you please, show which one is the common Y point out of the 4 contacts?
I believe it is the far left, looking at the contacts side...based on the resistance readings.
See uploaded image, where it has the + sign.
Thanks!!
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
