12 Kilowatt Free Energy motor generator for sale $4500
Started by e2matrix, September 11, 2022, 03:15:44 PM
e2matrix
Quote from: floodrod on September 14, 2022, 04:44:29 PM
My opinion means little here I understand, but I think there is no free energy here.
It takes big power to get that that flywheel moving up to speed.  When you loop it, there is enough stored energy in that big spinning mass to power drills and such for a little while as it slowly winds down.
As we all know- showing lightbulbs, drills, and loads means very little.  We need to see indisputable measurements of input watts verses output wattage.
Any claims of OU that are purely based on visual operation of loads set red flags off for me.  I feel if it were OU, the presenter would be anxious to show wattage on each side.  Or at the very least, show that RPMS are not slowing while operating a load. (or even without a load)...   Loop it unloaded and keep an RMP meter there for a few minutes..  Prove that it is not slowing..
floodrod,  Those are some good suggestions regarding checking the RPM's.   From the video:  https://www.youtube.com/watch?v=PB4w_fH4hgg
It sounded to me somewhat like the RPM's slowed under heavier loads and then sounded like it sped back up some when the load was off.   While he shows no wires coming in from the floor I do believe there are still possible ways this could be faked.   But it certainly looks to be done better than most if it is fake.
And thanks Chet for making calls and working on getting this validated or checked to see if it is just a fake.
seychelles
SO WHERE DOES HE RESIDE? PAKISTAN, INDIA OR TIMBUCKTOO.
floodrod
Quote from: e2matrix on September 15, 2022, 01:13:33 AM
I see what you are saying..  The video is indeed long enough to notice slow-down if it was happening.  It wouldn't have sped back up when load was taken off if it was under-unity.
But as you and others have pointed out-  the questions are "is it faked" and where is the energy coming from.
floodrod
Perhaps it is something interesting..  Here is a video with some calculations and a simple setup showing that any rotor with mass is actually overunity..  https://www.youtube.com/watch?v=hYw6tScZ7t8
The kinetic energy being stored is producing more mechanical work than the input power calculates to. The problem comes when trying to convert that mechanical energy back to electrical energy because of good ole Lenz..
Maybe flywheel kinetic storage and Lenz back EMF are not linked..  Meaning it may be possible to gain more from a huge flywheel than what back EMF takes away.  Something to definitely experiment with!
I have parts for a simple setup to experiment with..  2 identical PM motors with a heavy flywheel between..
partzman
Quote from: floodrod on September 15, 2022, 10:22:26 AM
I find this video very interesting as I'm working on a solution to nearly eliminate the Lenz effect in a PM generator and still produce an energy output.  The stored energy in a flywheel is a perfect solution in this case.  More later on this.
Reqards,
Pm
