audio amplifier as a power generator (instruction)
Started by dxer_87, September 21, 2022, 03:56:14 PM
forest
Możesz przesłać wideo po polsku, nie widzę problemu. Wystarczy dodać napisy po angielsku albo ktoś przetłumaczy.
kampen
@ DXER-87,
You wrote:
STEP. 9 Give a switch button to start your system from AC line.
To start only one phase is needed.
The installation though must not use residual current detectors.
A residual-current device (RCD), residual-current circuit breaker (RCCB) or ground fault circuit interrupter (GFCI)[a]
[size=78%]is an electrical safety device that quickly breaks an [/size][size=78%]electrical circuit[/size][size=78%] with [/size][size=78%]leakage current[/size][size=78%] to [/size][size=78%]ground[/size][size=78%]. It is to protect equipment and to reduce the risk of serious harm from an ongoing [/size][size=78%]electric shock[/size][size=78%].[/size][1][size=78%] Injury may still occur in some cases, for example if a human receives a brief shock before the electrical circuit is isolated, falls after receiving a shock, or if the person touches both conductors at the same time.[/size][2]
If the RCD device has additional overcurrent protection integrated in the same device, it is referred to as RCBO. An earth leakage circuit breaker may be a RCD, although an older type of voltage-operated earth leakage circuit breaker (ELCB) also exists.
Here we have a problem:
[size=78%]In Europe all GRID-Connected houses have a (RCD) standard installed.[/size]
Please advise how to proceed.
dxer_87
i made corrected version with new info :).
i think this will be the easiest free energy ever if done right :D.
dxer_87
if a residual current detector is used, i advise starting the system from UPS. or any 12v battery with inverter. this makes it even more portable. first, connect the grounding. also maybe when using my mentioned connection via transistor, the safety switch may not turn off the voltage. I didn't try yet, though my experience with residual current safety switches aren't fine for paulos.
hope this idea can help.
in Poland we use RCD only in kitchens and bathrooms separately.
Dxer.
dxer_87
Noplis is a kind of a simple trick with the phase. You need several metres of 0.5mm2 insulated wire. You go from where phase is.
You leave 30cm spare, take a ferrite rod 100mm minimum and wound around it about 50-100 turns then left another 30cm and wound the cable 20 times around the capacitors in the supply then you go into the switch of an amplifier. This is noplis. Some of amplifiers need only these and step up transformer to go overunity.
Hope You enjoy!
Dxer.
