Paired Electro Magnets telegraph and transformer.
Started by synchro1, November 17, 2022, 03:38:36 PM
Ufopolitics
Quote from: synchro1 on November 18, 2022, 12:16:02 PM
This high watermark video is as astonishing as Orstead's demonstration that electric current produces a magnetic field in a wire!
Synchro1,
What you are doing is nothing but basic stuff we all know it could be done...
The stack of Neo's magnetic field are exciting the EM's coils (generating a small current) when you tap them, which is sent via two wires to the second EM which acts as a receiver, which in turn, yes, generates a small magnetic field which barely moves knife.
1- You still need to "input" mechanical power to keep "tapping" neos...
2- Plus, if you use a larger transmission wires from EM1 to EM2, with higher resistance...then you will barely "see" any movement on the knife.
Now, if you could get the huge neo you are showing above, in between the two EM's...(maybe with a small plastic in between as a gap) then tap any external side of any of the EM's with the neo's stack...and connect a scope on the parallel wires...you may see an interesting bouncing of the field back and forth...which eventually will fade out to zero signal.
No intention here to disappoint you in any ways...
Ufopolitics
Edit: You need to cut the images size to 1000-1200 pixels in width in an image editor like Adobe Photoshop.
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
synchro1
Quote from: Ufopolitics on November 20, 2022, 09:43:28 AM
Synchro1,
Ufopolitics
I agree with you and welcome your input. My tests have shown that pulling the permanent maignet away from one side generates a neutralization pulse in the other! This means that cross wired, the attraction strength should kick the magnet off the other side 🙏 There is a chance this could run as a reciprocating oscillator with 2 spring pressure SPDT switches and no external power supply.
Magnetic Telegraph 5 - YouTube
synchro1
I discovered that cross wireing will neutralize bipolar magnets. Horse shoe type magnets attracted to the Electromagnet cores!
Ufopolitics
Hello Synchro1,
Well that is awesome!!...Yes, by cross wiring the two EM's, the Field generated on the receiving one, would be opposite to the one on the generating EM Coil.
It just gave me an idea... ;)
We could put together a sequencing where the "tapping" would be done by a Rotor with fixed Magnets, set at alternated polarities in PAIRS at 180º.
However, you will need to make more concise, accurate testing:
1-The magnet hanging on the fishing hook, must be set with polarities facing the center EM's core.
And if you could get this hanging magnet fixed (not swinging on the hook and line) then adding a way that the magnet could pivot from its center, it will show a flip of polarities when you do test 1 (normal wiring) and test 2 reversing the connecting wires.
2- Try just reversing the other stack of magnets polarities facing the Generating EM, when tapping it...without reversing wires, then the fixed flipping magnet on Receiver should also swap physically (once you hang it fixed and pivoting from its gravitational center.
This way you would confirm that in fact polarities are changed remotely!!
By sequencing this effect properly we could get a series of "Attract-Repulse" stages, which would keep the rotation steady without any external input...
That would be awesome!!
Btw, where did you get these Electromagnets?...I see they are Chinese, got the number and will search by it.
We will call this Motor the "Burguess Effect" first applied to a Motor.
Ufopolitics
Thanks!!
Edit 1: Plus, as you have said, using small roller micro switch SPDT could regulate an accurate flipping in a timing sequence.
Note, the heavier and bigger the magnets, the stronger the Effect would be demonstrated, because the generating field would be much greater.
―Leonardo da Vinci
synchro1
This is a pretty cool effect because a small amount of neutral zone flutter by a magnet between the two pot poles will be amplified by the twin into a powerful oscillation!
https://www.youtube.com/shorts/6z9zJnY3gvg
