Deductions from the Quaternion Form of Maxwell's Electromagnetic Equations
Started by Feb2006, November 29, 2022, 01:34:11 PM
Ufopolitics
The propagation of ANY Magnetic Field Force, whether generated by a PM or EM, is completely longitudinal in essence, it is more directly accurate than a LASER Beam pointer.
It has been a completely nonsense, -up to now- the teachings that Flux or the B-Field "only" merge outwards, from the North to be entering the South end of any Magnetic Field!!
All Magnetic Fields propagation of their Vector of Force, merge exactly from the very gravitational center of the field, towards each extreme end outwards, or so called "poles", and this forces expand into Space, and are -both- identical in length and amplitude.
All this could be measured with a very simple tool...a CRT with a Centered Horizontal Rastering Line.
CRT REVEALING MAGNETIC FIELD VORTEXES
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
stivep
Quote from: Ufopolitics on December 10, 2022, 09:44:47 AM
@ Alan: Nope, it does not answers my question, at least "not in full"...
But there is more to this...and here below, is the description taken from Thomas Minderle article, originally posted by member Feb2006, which clearly defines it:
QuoteMagnetic field - field that accelerates matter depending on its magnetic moment. It arises from the curl in magnetic vector potential. Its units are Webers/meter2 . Whenever there is vorticity in the magnetic vector potential, a magnetic field exists pointing along the axis of that rotation.
And in a very simple way IN ESSENCE: "The CURL in Magnetic Vector Potential"...which resumes in..."VORTICITY in the Magnetic Vector Potential"
_______________________________________________________________________________
really?
are you sure?
Well Well Well .........Houston we have a problem.
https://en.wikipedia.org/wiki/Houston,_we_have_a_problem
Magnetic field is:
a vector field that describes the magnetic influence on moving electric charges, electric currents, .
A moving charge in a magnetic field experiences a force perpendicular to its own velocity !!!
Because the force is always perpendicular to the velocity vector, a pure magnetic field will not accelerate a charged particle
the charged mass particle will not be accelerated!!!!
however will produce circular or helical motion
Speed, Velocity, and Acceleration  https://www.youtube.com/watch?v=rZo8-ihCA9E
Also: The charged particle's speed is unaffected by the magnetic field.
The magnetic field has no effect on speed since it exerts a force perpendicular to the motion.
Motion of a Charged Particle in a Magnetic Field motion-of-a-charged-particle-in-a-magnetic-field
: https://www.youtube.com/watch?v=rZo8-ihCA9E
is scalar   is vector        is  vector
So how particle accelerator works than? :
Particle accelerators use electric fields to speed up and increase the energy of a beam of particles,
which are steered and focused by magnetic fields.
The particle source provides the particles, such as protons or electrons, that are to be accelerated.
so particle  = mass e.g proton mass.
and magnetic field since it is perpendicular  acts
like if in analogy:
someone was pushing,  squeezing you to the ground while you  are trying to move
- you are being positioned.
Magnetic field also is used for positioning and steering but not for acceleration or speeding up,
Some sort of intelligent manipulator, may likely   make you to  start believe in spiritual, pseudo-scientific trash.
Yes the guy is intelligent but what is his agenda? hm?
look what we have there:
Gnosis: Alchemy, Grail, Ark, //Spirituality, Mythology, only       :$ 22.95  pay now and get a discount> WOW!!! https://www.amazon.com
Alien Disinformation: - Grays, Nordics, Reptilians, and Mantids :$ 13.85 https://www.amazon.com
and here you have  pages of  listing  and everything of that is for sale.  https://www.amazon.com
and yes: Ether is  there too.
Note: opinion expressed is my own, according to the Constitution of United States.
Wesley
Ufopolitics
Quote from: stivep on December 10, 2022, 01:15:50 PM
Magnetic field is:
All above concept (or sort of "Theory") is TOTALLY thrown out, by a simple, small, Permanent Magnet...which does NOT have any electrical charges, nor electric currents...it is just...A Magnetic Field, NOT generated by anything, but  being there, existing...so, now what?
Besides, on my post It reads very clearly a Magnetic Field accelerates MATTER, not mentioned any "electrical charges"...so, please, do not put words I did not mentioned.
like if in analogy:
NEGATIVE!!!
A Particle Accelerator could work with BOTH, Electric and/or Magnetic Fields...NOT only Electric Fields!!
A CRT is the perfect example of a small Particle Accelerator (electrons in this case)...and so, it works with Magnetic Fields or also with Electric Fields.
However, much more common are the Magnetic Fields to deflect the Electron Beam Ray.
Ufopolitics
WARNING: In order to keep this dialog in good shape, please remain from ANY offenses, ironies, or insults which are completely NOT NEEDED.
―Leonardo da Vinci
Ufopolitics
A simple statement:
If Magnetic Fields would not accelerate mass...then all magnetic (PM and Electromagnetic) motors should not work...right?
However, THEY ALL DO!!
Ufopolitics
―Leonardo da Vinci
alan
The magnetic field of a permanent magnet is also created by current, the spin of the electrons of the hard magnetic material constitutes the current.
