100 watts output with 60ma input
Started by joellagace, February 03, 2023, 05:28:31 PM
joellagace
Quote from: endlessoceans on February 19, 2023, 07:21:27 PM
If we work together you can make life and systems a little better.  Nobody is making outlandish claims but Joel IS Sharing his valuable time and observations for zero dollars.  That alone is worthy of praise
Thanks Joel
Thanks! That's more or less the thing and I have explained here and on my youtube comments everything I could. And the rest I explained already the best I could why I may not have every possible piece of data. "It's not a lab its a kitchen" Some folks will get really angry because I can't answer some technical question like what's the length of my cable going to coil in video number X. What can you do?
Glad you made good use of the info I shared. I know people are, I get private messages of those who are experimenting with similar/same thing.
Take care!
erfandl
Can you please put at least one schematic of the cap dump circuit ?
joellagace
Goat
Thanks @ joellagace
That helps...Occam's razor
Regards to all you do to help us :)
lesleyharrell
Quote from: joellagace on February 03, 2023, 05:28:31 PM
Thought I'd share this here. Here is my video of my latest device with Back EMF charging.
Runs an old school 100 watts 60 hertz AC bulb from the inverter, Battery holds and charges up at the same time from Back EMF cap dump. The back EMF stage controller only needing 9 volts DC 60 ma input to operate and produces hundreds of volts of BackEMF collecting charging a capacitor that dumps this into the battery 2 times a second at 100 volts.
https://youtu.be/QYpwTJJ3lh8
I fixed up my 9 volts dc 60 ma radiant trigger back emf and 100 volts cap charge and dump circuit controller and generator by taking away much of the high impedance test lead clips and replaced with  short thick wires. Especially for the back emf coil and cap dump stage. In a previous video. A more sloppy version of this I was able to run and maintain a 15-20 watt load from the charging battery without the v/i curve going down, It was going up!
With this improved setup, It now appears, I'm now able to do the same thing with holding a real 100 watts load on the battery while charging it with the radiant cap dump device at the same time . Heavy emphasis the whole input stage only needing 9 volts dc 60ma from a wall transformer power supply. This is my small input trigger requirement. That is it. The rest of the energy as Bedini would say comes from the Vacuum or Negative Energy. The battery reacts to these steady voltage discharges from the capacitor and transduces this pulse into real steady current of 100 watts while maintaining a v/i curve or charging curve instead of a decline curve as one would expect while running a 100 watt load for 15 minutes. A kind of negative resistor.
This video is a little longer, Its about 15 mins. I wanted to show you start to finish what goes on, Very similar to the "kromrey generator" At first start the battery shows a slight voltage drop of a few points, after 2 minutes the v/i curve stabilizes and soon starts to raise steady as long as the battery keeps getting that high voltage cap dump pulse 2 times a second all while maintaining a 100 watt load. I can hear a kind of boil sound when I put my ear next to the battery so it must be doing something! This setup holds the big 100 watt load without the v/i curve going continuously down, after about 15 min run time in this video, you really see the increase of voltage by many points in comparison to the start of this demonstration as the v/i curve goes (charges) up. Sorry for the length. It takes this much time to show you without editing the video what is happening. It runs the opposite! This is an awesome COP value. 9 volts 60ma input and 110 volts 100 watts 60 hertz output. Or more if you want to take the inverter power consumption as well into consideration and all other losses.
Thank you for sharing your video and explaining the details of your Back EMF charging device. It's interesting to see the results you've achieved with this setup and the potential for generating power from the negative energy. Your demonstration of maintaining a 100 watt load while charging the battery with the radiant cap dump device is impressive, and the increase in voltage over time is a clear indication of the effectiveness of your setup.
It's great that you've included the details of your input trigger requirement, and it's amazing that you're able to produce such a high output with just a 9-volt DC 60mA input. Your video provides a clear demonstration of the process, and it's helpful to see the entire setup from start to finish.
Overall, it's an exciting development to see the potential for generating power from the negative energy and Back EMF.
