Thanks to ALL for your help!!
Igors switcher (EMF recycler2)
Started by drspark, January 27, 2007, 09:25:42 AM
electrostatic
Quote from: drspark on February 03, 2007, 10:14:43 AM
Hi Pakis_ch,
My transformer is only 24 turns of two strands #24.
I measured out 3feet found center on ONE strand and sandpapered a bare spot and soldered the greeen wire on. Then I put both strands in a drill and lightly twisted them to make treading them thru the toroid easyer.
I connected a 12v lightbulb to the uncentertapped strand and wired the primary as showen in the various drawings...
It barely made red the filiment. So, now their both connected like litz wire but only one is centertapped to the diode.
Hi Spark!
Question about the toroid transformer.
Is this the correct schematic for the replication you made?
http://drspark.com/2cycle.jpg
http://drspark.com/6vbulbs.jpg
I?m unsure about the toroid winding.
You have two 3 foot lengths of  #24 gauge wire.
On one length  you found the middle and attached a green tap wire.
You then twisted the two 3 foot lengths together.
same twist direction for the length?
Or, twist one way to the tap then twist other direction the rest of the way?
Then the two  3 foot wires are soldered together at their ends?
Or is one primary and one secondary?
I?m unsure about your bulb connection . you said you connected it to the
Untapped 3 foot wire which suggests that at least on one end the
Two 3 foot wires are not connected together ?
Thanks,
drspark
Hello Electrostatic
In the final version of the relay circuit, the transformer was disconnected. Just connect the input diode to the top of c1/c2 bank,
and the output resister between the two banks.
like 2cycle.jpg with the inductors shorted.
The 1000uf C5 is also disconnected.
Hope this helps
Spark
electrostatic
Quote from: drspark on February 23, 2007, 02:15:26 AM
Hello Electrostatic
Hope this helps
Spark
Hi Spark,
Thanks.  I thought that the ?interesting? part was the transformer.
I still am not that convinced that the input bulb is letting RF through
and that , that?s the reason that the bulb is glowing dimmer than
the output bulb.
BUT,
As Tesla said himself I believe, about his fuel-less generator,
?The radiant energy system is a self-oscillating capacitive system. Once it is set into oscillation, very little power is expended in keeping it going. Because it is an electrostatic oscillating system, only a small amount of charge moves through the system per cycle?
http://home.comcast.net/~onichelson/Fuelless.pdf
From,
http://tesla.nichelson.googlepages.com/home
So I think you might be on the right track
gezgin
Hi,
Yes i tested 4 contacs relay switch device with 4*10.000uF/63V Cond. ,toroid coil,
power supply 12-18 V
condansator voltage was increase to 1000V and multimeter reach limit.Im worrieng conds.explosion .
in circuitmaker simulation, playing C&R values getting strange results & errors.
sometime show big voltages.
I have seen miracles happen to men and women in all walks of life all over the world. Miracles will happen to you, too?when you begin using the magic power of your subconscious mind -Joseph Murphy
hartiberlin
Hi Gezgin,
watch out, that your caps dont explode. Put a zener diode or a few white LEDs in series across them, so when the cap voltage reaches zener or LED threshold voltage, they will conduct and dont increa e the voltage anymore. Please post pics or videos. thanks.
