Thanks to ALL for your help!!
TopRuslan
Started by r2fpl, March 21, 2023, 11:47:39 AM
r2fpl
Quote from: pix on May 29, 2023, 11:30:13 AM
Do you understand COP>3 of a heat pump or air conditioner?
Large amount of low grade heat is converted into smaller amount of useable,high grade heat.
For heat pump example: 100m3 of outside air of 5 deg Celsius ( 5 degree C is not very useable for heating your home, isn't it?), into 10m3 of 35 degC  air .
The same principle Tesla Magnifier works.
Tesla secondary is a slow wave resonator, feeding harmonically into that resonator low amplitude signal of higher frequency- results in expotential rise of accumulated energy (amplitude squared), that could be discharged at much lower frequency.
So,, it is not any "free energy" or Overunity.
It is just clever way of converting low grade, othervise not useable  energy  into a high grade useable energy.
In Tesla style magnification we just need a resonator and a generator or LC circuit to produce harmonic oscillations .
You charge capacitor , once it discharges into the coil-oscillations are "for free"  ;) .
Cheers,
Pix
The problem is that it won't. You have 1Mhz and that makes 1W. If you reduce the frequency to 1kHz you still have 1W.
Yes or no ?
Fabon
Quote from: r2fpl on May 29, 2023, 11:39:12 AM
You're saying the same thing again. This is not meanness but the truth.
"Truth" that satisfies
Your personal fake wishes are here!
pix
Quote from: r2fpl on May 29, 2023, 11:44:55 AM
Yes or no ?
If you feed 1Mhz with let's say 1mV amplitude signal into resonator, after 10 oscillations amplitude in the resonator will rise to 10mV, energy accumulated after that 10 periods will be 10 squared=100.
After 100 periods, amplitude on resonator is 100mV, energy accumulated 100 squared= 10000.
After 1000 periods, amplitude on resonator is 1V, energy accumulated 1000 squared is 10exp6.
ect...
So, if you discharge resonator at 1kHz rate, you will have 1V voltage and quite large energy accumulated.
That's why Tesla named it "Magnifier".
it is intristic property of a resonator to accumulate energy that you feed harmonically into it, untill it will break loose.
r2fpl
Quote from: pix on May 29, 2023, 11:58:46 AM
ect...
Yes, but that's not what I meant.
forest
You need heat exchanger or in this case a method of condensing distributed free energy oscillations of very high frequency aka ambient medium aka white noise. Tesla did it using many inventions combined. In all cases like in heat pump it must work in a circle closed loop.
