High Amps from 3 Volts. Is this an OU circuit?
Started by Mem, May 25, 2023, 03:14:50 AM
Mem
Quote from: Ufopolitics on May 25, 2023, 08:42:33 AM
Hello and welcome!!
That is a very simple circuit but very interesting result!!
It would be great if you could add an image here of the full diagram with the spec's in more detail.
Like part numbers on the ebay HV Module, cap capacitance of the 5 blue caps plus number of turns on primary.
Or you could take some resistance measure on the 10 gauge spool...it should read the amount of total length on the label.
It would be very interesting to add meters to it...measure Input voltage ande drop voltage whenever you short spark gap and the manually driven one...
And measure amperage on spark gap wire(s).
Another interesting test that could be done, is to make the hole bigger on the spool (by taking off the small plastic to allow for a smaller shaft hole)
And inserting a steel rod inside that spool (it could be solid, no need for laminated steel for just a test)...that way the nagnetic field would be enhanced and much stronger!!
Many thanks for sharing it here!!
I am pretty sure many here would try to replicate it.
Ufopolitics
Hi Ufopolitics,
Slide the video to the very end and you will the part's names and the number.  The parts are not critical at all, if you can have or make an adjustable spark gap the circuit will work, without a doubt. This is true because of my past experiences.
The 10-gauge spool is sealed, I never open it at all, all you have to do is to get a very thick Cooper wire and put it around the spool maybe around 9 to 10 turns you will get the same or better results than I did.
Most people have all these parts in their junk pile other than a large spool of wire.
As I have said in my below reply under load input amp definitely goes down to half, why that happens I have no clue.
You said: (Another interesting test that could be done, is to make the hole bigger on the spool (by taking off the small plastic to allow for a smaller shaft hole)And inserting a steel rod inside that spool (it could be solid, no need for laminated steel for just a test)...that way the magnetic field would be enhanced and much stronger!!
Since this is a kind of dumb circuit (meaning there is no resonance) I wouldn't expect much change if the L1 core has a metal rod or not. But again it will be worth experimenting.
I was also thinking to connect a ground wire to one of the coils, but having tested the idea yet.
Anyone can replicate this circuit it's very simple and it will work as long as you have a spark gap and some HV capacitors 1000 PF range 30 KV that will get changed before the spark gap.
Mem.
Mem
Quote from: kolbacict on May 25, 2023, 03:11:07 PM
And why do you need a perpetual motion machine ?  What will you do with it ?
Maybe you already have it ?  You even die in peace and bliss and without suffering. :)
Can you please elaborate on what prompted you to write these comments above?
kolbacict
Hey, forget it. Then I was a little drunk.
What was said is generally true, but  it still won't change anything. :) :)
Think signal as EMP,
physicalyy as surge effect,
Dirac sea(Moray ses in Physics unused) surge = Dirac surge
Is an EMP unidirectional ? Bi-lateral,physically ? Reflective ?
Your,the device,its switch on cycle phase energy(or micro-/nano-/power input ) versus total ,a. in vaccuo b. in air,cold hot c.in liquid : cold,hot  output !?
Chain re-/action !?
Each time new inertia input or after cycle inertia phase given parameter ( quantity,quality) hold on continuous cycle minimal work input need !?
Parametric motor and parametric generator couple : ~ reversible resonator
  parametric EE Carnot dynamic cycle
A fine weekend wishing
OCWL
nix85
Such sparks are very misleading, i was producing even larger sparks of same kind when shorting the secondary with not much input in my failed attempt step down Don Smith secondary but lightbulb never lit more than input power.
Don't you have a clamp meter, if frequency is high due to LC oscillation full wave rectify it into a cap and measure the DC.
If there is excess current it may be a second "spark gap" effect or combined effect of two spark gaps, obviously second one is not a spark gap but sudden change of impedance and material. Radiant can pour in at such transition zones.
Back in 2006. Stefan has suggested William Alek of Intalek to use graphite/carbon rod instead of steel pipe based on the fact Joe Newman used rough/scratched "bumpy" graphite brushes in his generator.
https://slideplayer.com/slide/4499753/
http://www.intalek.com/Index/Projects/SparkGapExp/SparkGapExp.htm
https://overunity.com/716/carbon-arc-spark-gap-cop-calculation/
https://overunity.com/760/update-excess-energy-observed-in-carbon-arc-experiments/
https://overunity.com/713/update-excess-energy-discovered-in-spark-gap-experiment/
https://overunity.com/708/update-testing-the-perreault-valves/
Alek made number of overunity claims but nothing conclusive came from him, i saw a video of him supposedly demonstrating a small scale overunity like 150% but very small power. It may or may not have been overunity, but in any case nothing conclusive or of useful scale.
Quote from my post about spark gap gains
To quote Don
"spark gap is actually control the level of energy that's passing through there you can do it without the spark gap"
https://youtu.be/_8JwIlHLOUI?t=7590
Point is sg is just just a sudden change in impedance and can replaced by sudden change in thickness of cable, if used for timing by a fast BJT, MOSFET or IGBT (which is a npn mosfet driving a pnp bjt) or just omitted completely.
Few quotes about sg gains...
"V. Mitkevich published a strange observation in Russian, in St. Petersburg, in 1905: an interrupted arc discharge showed an anomalous energetic "kick." The voltage in the arc reversed at the moment when the arc was disrupted."
https://www.infinite-energy.com/iemagazine/issue133/forgotten-inventions-of-lenr.html
William Alek tungsten carbon sg gains
"The Correas have now convincingly demonstrated the principle that it is possible to release from charged metals in a vacuum amounts of free energy which exceed the amounts of energy put into the system."
http://www.rexresearch.com/correa/correa.htm
"energy available at the output of the helix of the traveling wave tube is 96 times the energy input to the traveling wave tube, in addition to the energy consumed within the traveling wave tube and the energy available in the form of collected particles at the collector electrode"
http://www.rexresearch.com/ev/ev.htm
dieter member here
"Experimenting with a 3kV Sparkgap, shocking a graphite core, I observed strange reduction of power consumption"
https://overunity.com/12328/radiant-electriciy-generated-with-spark-gaps-and-induction-coils-theory/msg502989/#msg502989
Electroboom current draw goes down when sg fires
https://youtu.be/m7VP36diOKY?t=135
"In fact some investigators have proposed that an abrupt voltage pulse with only (vacuum) displacement current and minimal charge motion is sufficient to produce anomalously excessive energy. Bearden (1993) proposed this is his final secret, and Hyde (1990) used this principle in desgining an invention (a mechanical electrostatic field chopper) that reportedly output 20KW while self running. Hyde stressed there should be no corona present whatsoever."
Quest For Zero-Point Energy: Engineering Principles for "Free Energy" by Moray B. King
"Dr Chernetski demonstrated a device which showed enough excess energy to burn out a power station which it was connected to in a test. It was based around a spark discharge in low pressure hydrogen. Dr Chernetski was then killed in a car accident and his worked taken no further.
In a simpler test he also showed that with the right spark and less "expensive setup" could show a decrease in draw current with an increase in the load."
https://www.nuenergy.org/chernetsky-plasma-generator/
And so on ad infinitum
But, again, it can be done without.
