The Deaf Were Not Able To Obtain The Dr. Flanagan Nerophone To Begin Hearing
Started by russwr, August 03, 2023, 09:56:20 PM
russwr
The late Dr. Flanagan had several alternate energy devices/ systems, including the space ion drive invention  that was purchased by US government. I was mostly interested in the communication system using the ETHER and line of sight type. The Neurophone changed audio picked up by microphone to RF that the brain picks up directly, so as the ears are bypassed. There were several different models. Patents were applied but quantity production not done because government  officials said it enhanced ESP abilities and the general public should not have these, and should continue being deaf.
https://patents.google.com/patent/US3393279A/en
https://patents.google.com/patent/US4834701A/en
Both their cited/citing documents shows us the a.frequency spectrum and device/s use potential !
Neuronal re-/programming,NLP-tools .
wmbr
OCWL
rakarskiy
Such devices are made by skillful people themselves, both through contact method (electrodes) and through capacitive coil. Low-power, 5 volt power supply is enough. There are already specialists who encode by frequency modulation therapeutic programs and medicines. I made such devices myself. The result in some cases is amazing, there are times when it does not work.
"Vortex medicine is a new alternative holistic medicine with a holistic approach to treating diseases. It uses the high-energy torsional field of the immaterial human body to treat diseases of the material physical body."
how this immaterial body - torsion (information) field looks like on the photos taken in Kiev in the 90s of the last century.
"torsion" is not a physical name, it's esoteric.
also an example file for modulation in treatment procedures called "colds1".
Also the scheme of the simplest device for bioresonance vortex medicine. The transmitter is a bifilar tesla coil with an inner diameter of 25-30 mm. It is connected in capacitance mode: one wire on the outside, the other on the inside. Important!!! That the natural frequency of the bifilar coil was within 300-350 kHz. The input signal must be processed so that the lower potential does not fall below the value at which the coil's own resonance collapses.
Warning! The circuit is given for comparison with the mode of the circuit from the patent. Personal application is your own responsibility!
rakarskiy
Oscillogram of the signal of a bifilar capacitance coil at the resonant frequency.
With modulation, the voltage and current will drop to a lower value.
kolbacict
I know this master oscillator circuit. Feedback with a phase shifter.
The question is, why three variable resistors, three adjustments ?
What do they give? What do they change ? As usual enough one,
or nothing at all.  ???
