Pulse Motors- Your building them wrong.
Started by tinman, August 30, 2023, 12:55:41 PM
Thaelin
MagnaProp
Quote from: tinman on September 01, 2023, 07:18:43 PM
Those neo magnets will do the job just fine.
The idea here is to spend as little as possible, and use what you have lying around...
Great. A few parts have arrived, the power unit and such. I'm still searching for a wheel. The one that arrived turned out to be aluminium and not steel as described in the add.
Going to try a Wheelbarrow wheel next. Those usually aren't aluminium.
I've looked at some cast iron flywheels. I've heard those can explode at high revolutions since the metal isn't made for spinning that fast. I've never built a pulse motor so I'm not sure if we get up to such high speeds or not.
citfta
I agree with i_ron.  My experience with this motor is you will probably see speeds of between 400 and 600 rpm depending on you building skills and proper tuning.
Carroll
MagnaProp
Thanks i_ron and citfta for the info. I'll try to get something working first then worry about breaking the sound barrier with the speed.
I received this white wheelbarrow wheel today. A magnet sticks to it so that sounds good. The rim is about 8.5 inches diameter and the solid rubber tire was easy enough to cut off with a long box utter and wood chisel I have. It's a wheelboarrow wheel so the bearings aren't exactly super smooth but hopefully we can get it moving. Now to find a way to attache the little metal part to this rim.
