Oil Furnace Ran On Water Line In 1950!
Started by russwr, September 05, 2023, 12:28:50 PM
marcosbk
Agree.. Both mention superheated steam for improoved burning
ramset
Here from Japan 2006 ? (I believe has been posted here many years ago ,and again since then)
https://m.youtube.com/watch?v=v8PbdymGFk8
(I believe above was shared by member Johan 1955 years ago emulsifying water/fuel )
EDIT To add
Above video claims more heat out with 50% water emulsion
Always thought some proprietary formula ( "specific ION " mentioned in claims)
Now ?
Maybe easier than we thought
Respectfully
Chet K
PS
Edit
Grumage had shared this year's back
https://m.youtube.com/watch?v=n3f8v9bjx7g
26 minute mark
Water boom ( frequency?)
Recently Grumage was referring to some water pump he had seen a patent on
From early 1900's
Used frequencies to manipulate ( pump ) water in a column ( with nodes at specific input and diaphragms and ??)
Was looking for that when I found other contributions ( posted in this reply)
Still haven't found the pump he referenced !
Thanks Grandma
ramset
Repost for Smudge question
Quote from: russwr on 2023-09-05, 17:30:34The US Patent issued was NOT what was asked for in the complete application manuscript in 1950. Patent said steam mixed with fuel oil.
Smudge question:
How do we get sight of the original application manuscript?  The patent mentions application number 291691 but the USPTO classification system requires two more numbers preceding that 6 digit number.
Smudge
End quote
Thanks Grandma
russwr
  The US Patent issued was a 7 digit number only, For the so called Jackson water burner -as it was called.  2,863,499  Patent does not include any over unity data , or mention of self running mode, or mention of free fuel. There is no more tech data from manuscript - as it is the same as explained in the above paragraph written.  Patent Dept does not  allow that for the public.  The Patent examiners reworded the tech data to suit them, for an up to 50% increase in efficiency of fuel oil with added steam, and decreasing hole size of pin point oil spray nozzle. You would also have to figure out how to get free quantities of mineral free distilled water. (non clogging of heat exchanger and small orifices) Waste heat to distill plain water, solar energy with Fresnel lens concentrater, or or obtain the waste water from commercial refrigeration systems building that runs distilled water drippings line down the drain.
marcosbk
"you would also have to figure out how to get free quantities of mineral free distilled water. (non clogging of heat exchanger and small orifices)"
Best is rain water. Sometimes even better than comercial one. Definitely cheaper. With a TDS meter can be verified
