Is this the first selfrunning overunity motor w/o batteries ? Mike?s motor
Started by hartiberlin, February 14, 2007, 08:30:03 PM
acidbreaker
The guys in the CERN are going wrong way  ;)
that is the clue   :)
SPP-48
Just an update for those interested. My motor has been running on the same batteries for 148 hours now, although the voltage is now at 2.38v. I expect it will stop shortly.
I have been trying different capacitor configurations. I now have a bank of 12 x 1000uF 63v in parallel as providing the best results. I found the 1F & 22F caps difficult to evaluate as I could not charge them up with hand spinning the motor. Once the cap was charged with a battery the motor just ran and ran. I stopped it as I realised that it might just as well be connected to a battery.
It's interesting to note in Dingbat's summary that Mike said to use three magnets on the flywheel. For what it?s worth my best results so far were when three magnets* were aligned between the rotor magnets - from the top :  N * S  - N * S -  N * S. Although I still have a reed switch set-up without a relay.
I still need to order the hall IC and relay.
SPP-48
McGiver30
helmut
@SPP-48
Thanks for the replay.
For a moment i was thinking,that you got it working as Mikes Motor and you were
preparing a Video Demonstration,to show us the myrical.
Who knows..perhaps it is a matter of a few days.
Can you please list some information about the Setup of your coil arangement.?
And perhaps some detais too.
My own setup is in rest,because i wait for the Osziloskop to be delivered.
So long every day i see the thread to be informed and i guess,that many do so.
Did you make mesurement about the weight of the Rotor? This might be a important parameter to kalkulate the Power,that was supplied by the system to keep the Rotor moving that long time.
Some ideas i have in mind.
One is,that there must be a simularity to a otto motor. To get the most Power out of the Piston,it ist important to setup the best Time/delay of the Point,that the spark is flashed.
In my opinion is the fashback (from the power out of the Cap) a very signifikant point in the relation between the magnet and the torque.
Perhaps it is easy to prove in your stetup such a adjustment.
Your Batterys do not increase the Voltage.It does not mean,that there are no Elektrons be moved to the Battery.It doese mean,that the voltage level  is not
different enaugh to encrease the tension.
I which much succsess to you. At the end all of us will profit from this research.
Regards from Duisburg
Helmut.
hotspringstrading
One thing I am woundering is if the vom he used was damaged backfeeding voltage to the circuit.
