rotoverter for power generation
Started by dan, May 02, 2005, 03:57:50 PM
esaruoho
NeonPeakTrigger circuitschematic + pictures + explanation by Patrick J. Kelly, with collaboration with David Kousolidas.
more info at
http://peswiki.com/index.php/Directory:Rotoverter:Replications:Deliverance
esaruoho
NeonPeakTrigger writeup by Patrick J. Kelly.
D2 by Patrick J. Kelly (heaps of RotoVerter info on page 16 onwards)
http://peswiki.com/index.php/Directory:Rotoverter:Replications:NeonPeak
esaruoho
"I got a 7.5 HP 3phase motor from the dump and started running that with the mains in RV mode, via a variac to get it to run off around 100V ac. Then, I was able to switch from the mains over to the inverter power, and then to increase the frequency, speed and reduce the duty cycle."
"in summer 2006, many in the EVGRAY group were discussing different methods of resonant collection, in particular the "Diode Plug" method, given by Hector. So I uploaded another add-on circuit to the inverter which synchronized the switching of the Diode Plug with the Deliverance Inverter. this was called the Deliverance, because the resonance recovery circuit used the triangular wave in the original Deliverance Inverter."
"In April 2007, after Hector suggested the idea of using a Neon to detect the peak voltages in the Diode Plug, I uploaded a revised resonance recovery circuit, which doesn't need to be synchronized to the Deliverance Inverter because it detects and synchronizes to the actual voltage waveform across the resonant capacitor in circuit. I called this circuit "Neon Peak Detector and Switching V1.3", because it can operate with mains or any inverter. It is quite a bit simpler than the previous version (Deliverance RV resonance Recovery 1.1) which it supersedes, and yet is more universal.
"Patrick- Why would your average individual want to build and use this circuit? Looking at the circuit from a beginner's point of view, it appears to be a variation of John Bedini's solid-state circuit where one capacitor is charged (from back EMF?) for dumping into the battery and the second capacitor is charged up until the neon fires and operates the opto-isolator to trigger the SCR to feed the capacitor energy into the battery."
"David- Yes, that's it in a nutshell. The crucial part is the timing of the dumping into the battery in relation to the voltage waveform across the Run Cap (and Diode Plug Caps).At the peak voltage on one diode plug cap, is the moment when the alternate diode plug cap(previously charged up) is dumped into the battery. The Bedini circuit you describe sounds similar, but I'd like to see it before comparing. "
