rotoverter for power generation
Started by dan, May 02, 2005, 03:57:50 PM
b0rg13
Quote from: esaruoho on August 31, 2007, 08:22:04 AM
b0rg13.. please consult http://peswiki.com/index.php/Directory:Rotoverter:Replications:Panacea
which is the newest version of that rv step by step thing.
but please also visit the panacea website and consult the other PDFs where you will find further information.
thank you very much , i appreciate.
if you want to get out of the rat race,you have to let go of the cheese.
Mem
<<Hi All out there,
What you guys think of getting this generator here http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=45416
and using 20 HP, 3600 RPM,  3P Baldor motor in RV mode, couple them with a (say 20 lbs of)  flywheel together,
With this priciple there no battery or inverter;
After system put together, then turn the  primemover on with AC then once the motor gains the full speed n torque with a 3 way switch instatly turn the primemover to run with our AC generator.
What do you think will happen, will it sustain itself? Or will it slowly slow down and stop?
If will sustain itself? Do you think will it give access power out is well or not?
Mem>>
ashtweth_nihilisti
Hi Mem, we dont have allot of test data on that process sorry, and or any Schematic, i thought its best to put it there but Im afraid its a 'half baked idea'   :)
Gene tried to get a Sch out of Hector but no luck, so we would have to rely on the lb tests to tell.
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
Mem
<<Hey guys
Yesterday while I did lots of testing on power consumption
on these motors. I had a hard time believing what I was seeing
on the watt/Amp miter.
Little fan motor coil that uses more energy than other 2 lot bigger motors!
Folks, (RV) resonance electric motor conversion method, can give us all the free power
we need if we could find the way to couple these motors with the right generators.
Mem>>
b0rg13
how did u put them into RV mode ? , is ther a step by step way to do it ?.
