High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
hkyle
It?s easier to be forgiven than it is to get permission....
hkyle
maybe I should have put this in the half baked ideas page. lol
IronHead
Well now you found what I am doing so lets get back to what we are doing.
Lets not get to far off the basic as far as the post goes , Thanks
Grumpy  I know you want to add to what was just posted as you know more about me than the rest do ,or maybe we should just leave this one alone  eh
Back to the basic cell
You and Grumpy were figuring out way my little basic cell stack works
v
hkyle
well then where were we?
ohhh but I know how your basic cell works...If I figure anymore I will just end up deleting more posts....lol
That little blurb I deleted was a theory I thought of back on march 17.
Walter Hofmann
Hi iron head,
hmmm I just read this and your question to show you anyone or anywhere that produce this much parahydrogen, well I can I brought up and showed with my picture last year allready the double unit and introduced the connection what you showed here meaning the negative in the middle and the two endplates connected to the positive and I got profen to generate 1.5LPM with only 12 V and two times 6 cells 2.5 X 3 inches plates. by the way did you ever measure the voltage on each cell? in a setup like this you have a verry high voltage with 36V on your two times 8 plates = 7 cells divided by 36 V and you have 5.1V per cell what is way to high. maximum for this amount of cells should be 18V not to go higher then 2.5V on a 1/4 inch spacing.
I have build the same setup with two times 5 cells and generate 2.5LPM with 12V and 15 A.
I just thought to put in my experience.
greetings
walt
Quote from: IronHead on April 27, 2007, 04:13:09 PM
Quote from: pg46 on April 27, 2007, 04:11:44 PM
Hi-
You all got to seal the electrolytes between the plates to build the classic "series cell" just as Bob Boyce has shown for years now. Otherwise there will be WAY too much voltage leakage between the plates and you will not have even distibution.
Don't waste your time building a cell without sealing them. Only the gas should be what is connected between them all. I have used round orings between plates which have worked out real well for me if you don't feel like cutting square ones. You'll be looking for between 1.5 volts and 2.2 volts in each cell.
You can build these units up to 70 plates plus even. The advantage is that with the lower amps you will not create too much heat which always will give you trouble when you have 'Amperage Runaway' which is not fun. Build the proper series cells.
Best To All,
I am not god I can't delete post that confuse people because the poster did not read whats going on here!
we ain't even on page 46 yet
Ok , I know now there are going to be people coming in here not reading anything with all the answers with nothing to show. I put this to them with there ideas and concepts , mathematics and such . Show me anywhere in the world someone or something producing this much ParaHydrogen  at 36vdc in this tiny area that I have clearly shown.
If I find this impossible to do in this forum I will build a forum where this can take place.
Thank you
