High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
kokomoj0
can we guess?  LOL
taking the plates out i would think would decrease the gas and increase the amperage, i am testing myself to see if i understand any of this LOL
kokomoj0
Quote from: magnetar on June 05, 2007, 10:26:54 PM
Quote from: Moab on June 05, 2007, 09:42:26 PM
That sucks. we need a vacuum pump too? Just kidding. so whats next?
You can get plenty of vacuum from the engine.  :)
not if you floor it and open that butterfly all the way up!  That part has bothered me because the result is inverse of what is needed!
we would need more vaccuum when more power was demanded so its backwards from what we need.
magnetar
Quote from: kokomoj0 on June 05, 2007, 10:34:22 PM
can we guess?  LOL
I read that adding neutral plates produces more gas with less amperage.  Im interested to see you post your results.  ;)
magnetar
Quote from: kokomoj0 on June 05, 2007, 10:36:48 PM
I suppose that depends upon where you feed the HHO gas into the engine.  Are you trying to run the engine entirely on HHO or are you mixing it with gasoline and air?
What kind of engine do you plan to use this in?  A fuel injected with O2 sensors?
IronHead
Don't think , DO!
Then you will know
kokomoj0 we will get into the whole of vacuum  in time. There is a way.
Vacuum chambers and plenum/throat loop I will show this as well.
We are not building what has been we are building what will be  and the "has" will
be assimilated .
Stop thinking with the brain  let the mind guide you
IronHead
