High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
0 Members and 18 Guests are viewing this topic.
IronHead
I hope to get to the NS-T cell but understand it must be replicated in exact ways.And if it goes boom it goes BIG BADA BOOM. Nothing like the RF cell but still  it can blow parts off your body in an open state and in a closed state ,much worse.
Back to HV  at 200 volts and about 50 amps you should have a cutting welding torch.
If you want to make a torch that does not need gas bottle replacement  start here.
Other wise you are just observing the effect of volts/amps matters.
This also includes the little buzz you are getting from  running AC through a rectifier without a smoothing cap.
kokomoj0
Quote from: IronHead on June 06, 2007, 03:56:08 PM
Like the 5th element!   LOL   yeh i was thinking about that too....   like getting a bunnch of 1/16th rods and making a 7 x 7 plate with them just to mess around but instead i figured i would wait till you are ready to teach it  :)
popeye68
Hi guys ,
nice forum!
great thread!!!
@Ironhead:
can you explain what went wrong with your RF setup so we know were to
stay away from ? :o
I have been fooling around with HF pulse generators on my cell , dangerous to?
(and planning to use a satelite LNB as transmitter in my cell...........  :P)
I will be ordering some SS later this week and build me some neutralplate cell ,
when thats ready i will post some bouble pic's.
@d3adp00l
Let's calculate with a car at normal cruising speed ,
first with gasoline then converted to hydrogen
consumpsion ;
Air weights 1,3grams/liter
gasoline weights 720grams/liter
ratio=553
amount of air per liter fuel:
air/fuel=1:14.7
14,7 x 553 = 8129 liter air per liter fuel
2liter engine
1:10 (10 kilometers/liter fuel milage)
speed 100kmh
10km each 6 minutes/ 1 liter fuel each 6 minutes
8129 liter air per liter fuel (every 6 minutes at 100kmh) ,
1354 per minute ,
22,5liters air each second.
Asume a 4% to 74% hydrogen to air usage;
(2/3 of hydroxy contains hydrogen)
amount of hydroxy a second    (increasing power)
   at   4   %      1,4   liter
      8   %      2,7   liter
      12   %      4,1   liter
      16   %      5,5   liter
      20   %      6,8   liter
      24   %      8,2   liter
      28   %      9,5   liter
      32   %      10,9   liter
      36   %      12,3   liter
      40   %      13,6   liter
                          etc.
Sound fair ???
IronHead
Quote from: popeye68 on June 06, 2007, 06:09:32 PM
Hi guys ,
nice forum!
great thread!!!
@Ironhead:
stay away from ? :o
Welcome to the forums popeye68
Yes experimenting wit RF itself is where it went wrong. No  using to much water is where it went wrong. I knew better than to fool with 2 oz of water at a time. If you mess with RF treat is like a stick of dynamite and  use drops not onces .
If you cold vaporize the water it will go boom when you hit the right RF Feq.
aslong as your gun is made right.
And never do RF in a photon light chamber in UV or IR with alot of water.
LNB , for RF you will need to build a multichannel transducer to sweep the range
Make sure you put a receiver on this thing and you know why.
That should be enough to keep you busy, kill you or bring MIB around.
Thats all I will post about this subject , for now.
kokomoj0
i wonder if we can simplify this by just using gas mileage as a reference to get us real close?
i get 20 miles to the gallon at 80 mph with gas.
So 1 gallon of gas will take me 20 miles.
How many liters of HHO at 0 psig = 1 gallon of gas? (and will take me 20 miles)
