High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
kokomoj0
Quote from: hartiberlin on June 08, 2007, 08:58:41 PM
Especially this video is very important,
cause he shows an actual ride in a homemade "terpine"
fueled car with hydrogen boost.
http://video.google.de/videoplay?docid=4463667203960833886
Can all be selfmade !
So how do we produce this homemade fuel Terpine" the easiest way ?
The car has a 700 miles range !
Incrediable !
Regards, Stefan.
Its biofuel.   he talks about mixing biofuel (carbon) with hydrogen..  Apparently algae is a good source
http://www.renewableenergyaccess.com/rea/news/story?id=47237
IronHead
Ok , An O2 sensor is nothing but a temperature sensor. It takes the temperature of the exhaust and feeds that to the computer. The computer adjusts the injectors based on this info to maintain optimal burn temps. HHO as a fuel enhancer runs at a different temp altogether . You engine will still run with no modification to this sensor  but for economy purposes we do this. It will be a good idea to mod this O2 signal so that it matches to the signal before the HHO was introduced.
Any vacuum is good vacuum
hartiberlin
Quote from: kokomoj0 on June 09, 2007, 05:44:42 PM
Incrediable !
Regards, Stefan.
I think they meant Terpene or Terpine( German Terpentin),
which is destilled from woodgad.
So heat wood or pines and extract the produced gas and cool it down,
so it will give you Terpentin or Methanol ?
This then mixed with hydrogen will get a very good fuel.
But you are right, algae have a very nice energy production as
biomass fuel and nutrition stock and food stock.
Also it can wash out heavy metals fromyour body and remove
contamination with these heavy metals, especially if you had
Amalgans metals in your teeth !
Regards, Stefan.
kokomoj0
Quote from: IronHead on June 09, 2007, 07:15:29 PM
Any recommended amount?
Do you have any advice to further my t cell?  Do i have to start over?  LOL
IronHead
You should  set it aside and build the cell from page 14 which is one module.
