High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
rapttor
I know of the EFIE, and know that it's in the pcm catagory (pre-control module). A board that takes the incoming signals... (ohm value changing) see's this and adjusts things like injector pulse width...etc.
Well, when I was trying to diagnose an issue I had on my 01' V6 Tundra, I learned a bunch of inside geek tricks. One of them envolved intercepting the Engine or Coolent temp sensor resistance changes in the wires running back to the ECM / ECU, putting a pot inline with it, and you could by keeping the engine thinking the engine is cold, it keeps the pulse width to the injectors on the "rich" setting. This was primarily for the guys running boost of some sorts. But you can also go a certain distance the other way, you can lean things out as well. To those who know this is referred to keeping the engine in "closed Loop" mode. You intercept any of the incoming signals you can change how your engine runs...
Sorry the Geek in me just made you all suffer through that blathering...
-rapttor
Successfully Perpetually Failing at everything I do...
keithturtle
All's well on my side of the mountain, but lots of other things going on right now.
Just built the Elenco FG500K and will test soon.
Got a newer scope as well, now to figger out how to use it <grin>
Got a load of 1/2 and 1" polypropylene, as well as sheet PVC from  the scrapyard... lots of stock to work with, no time to do it.
Turtle
Soli Deo Gloria
rapttor
[q]lots of stock to work with, no time to do it.
Turtle[/q]
yeah, those wives can get in the way huh...(i feel the pain)
PULSED)ReverseH/Ofuelcell
Looking forward to your test results Keith,
Got my chokes made, all I need is to fix me frequency generator (need new transistor BUZ 350).
More to come, ill be giving some info back a the Water fuel cell Forum,
Keep me posted,
Pulsed,
gotoluc
Hi all and IH,
I did 2 tests on my cell, both at 12v only. However not much result. With the water level a 1/4" lower from the top of the plates (see first pic) I only get activity at the center negative plate and a very small amount at each positive plates, (which are gooped at the outside back) I get nothing in the neutral plates. Also it draws only half an amp with lots of KOH added. At first I used small amounts of KOH treating the same 4 liter distilled water jug and refilling the cell and test again but had no activity, so I started using a 16 fluid ounce container of KOH (one at a time) to the water jug and retest. I stopped adding KOH when I was up to 4 full 16 ounce containers of KOH but still not much activity and amps. So I decided to fill the test container to go above the plates. Now more activity and amps but again only the center - plate and a small amount at each + plates but no activity in the neutral plates. I don't understand what I'm doing different other than the bottom of my cell is sealed to keep from voltage leaks.
Any suggestions?
