Plasma Electrolysis by IronHead
Started by IronHead, March 08, 2007, 06:31:51 PM
rapttor
@I.H. I have never seen it in sizes much above 1" - 1 1/2" but according to this site, you can get diameters up to 24"... that be a BIG pipe!
http://www.harvel.com/pipecpvc-sch80-dim.asp
Just a thought, but has anyone ever tried gutting one of these lights? Might make a good chamber, and the glass already has to endure high temps... the flouro version isn't too bad of a price.
http://www.e-conolight.com/Product/EProducts.asp?ProductFamilyID=7
Successfully Perpetually Failing at everything I do...
hkyle
Thanks rapttor, I have never seen it either but I will keep a look out.
IronHead these container ROCK....Great idea....The only thing that i would be concerned about (for me anyway) is the abiltiy to see what is going on in the chamber, so I would need some type of looking glass.
With the PVC or CPVC I was going to cut out some of the side and put on a plate of acrylic, or something else. It won't be bad when the water is circulating but just sitting there for tests it could get a little hot....
Thanks guys.
Quote from: IronHead on July 26, 2007, 02:30:22 PM
I started out using one of those heavy duty clear plastic filter housings . It worked for a little while but started to degrade . Cracks formed up the sides of the housing . It never leaked but they got pretty bad .The whole case also started to become cloudy looking.
So now I use the 316 stainless steel version . Like this rated at 300F
http://img.alibaba.com/photo/51972084/Filter_Housing.jpg
I would like to get one of these things some day and do a triple stage unit.
If I do I will make sure I post its construction this time before its all tucked up under the Motorhome.
http://img.alibaba.com/photo/51975676/Water_Purification.jpg
I am not sure about CPVC as I have never seen it larger than 1" pipe
It?s easier to be forgiven than it is to get permission....
IronHead
I cut a hole in the side and welded a sight glass to the chamber  with the Pyrex type  port.
Something like this one. Got that idea from Moab.  before that I could just hear if it was working well or dieing.
http://www.globalspec.com/FeaturedProducts/Detail/JohnCErnst/Threaded_Male_Sight_Window_Model_304/37741/0?fromSpotlight=1
Those lamps are a neat Idea as well.
hkyle
Well the only price I could find on those ss filter housings were $220 bucks ca....ouch lots of cash for a test mod...
I guess I'm stuck with drilling a or some holes in my ss tanks from the good ol distiller. I need most of the parts from it anyway.
This might work better for me cause I was going or will be going to the dump and grabing an old furnace. Gut it and have a forced air hot water furnace for the shop.
keithturtle
hkyle:
IronHead is right, brother- yer building a heater.   That thar PVC bucket of yers oughta handle the heat fer a while, whilst y'all git yer arc spacing right.  I got more parts, no time...
I got a clear bucket like what a restaurant uses in food prep, and suspended stuff from above.   Can't do pics right now.
I was checkin' about that cast acrylic 4" tubing I bought for some other cells, but I cain't find the site.  Had good info on heat ratings, thought is was good for 280'F before it gets mushy.
More next week.  Thanks fer all the input, folks!
Turtle
Soli Deo Gloria
