Plasma Electrolysis by IronHead
Started by IronHead, March 08, 2007, 06:31:51 PM
IronHead
30amps was a cold start up in  this specific cell, once the arc is archived the amps will drop rapidly . Cold was in 40F water in the winter.I can not say if you cell will start at 30 or 10 amps  you have to experiment with this
. If you can not supply start up amps as High as your cell requires then pre heat the water.
Just build it
Robb077
thanks. Yep, just build it...working on this trying to get my electrical engineer friend to help, since I don't know much about power supplies, square waves, sine waves or how to tell the difference...not trained on ocilliscopes at all. Just know the idea is workable and you are very practical in your application of the technnology.
IronHead
Also as Moab has stated do not use  glue of any kind in this cell.
Everything must be hard built and hard wired. Don't put anything in this cell
other than described . A Gummybear could transmute into  the most deadly poison known to man. Well thats a stretch  but you get what I am saying.
We just dont know enough about what turns into what in a cell like this
Robb077
Ironhead:
Great info. You know where you can get ceramic tubing with 1/8 in inside diameter?
what model for the electrical components? Exact model numbers or specifications on what is needed to "do it". Just an AC rectifier or full DC power supply with all the controls? Sounds like there should be some more detail so I can go to the store and give them a parts list. Maybe from Granger? Maybe you need to be an electrical engineer to know all this clearly.
IronHead
Sandblaster tip works  cover the rest with Teflon tubing. , and just start out with a full bridge rectifier , wire it up and plug the thing right into the 115ac  wall .
