new magnetic motor goes 2000 rpm without load 1000 rpm with load
Started by magnacoaster, March 09, 2007, 01:37:35 AM
OffGrid rdnck
For all the money and time you've spent, and lets not forget all the energy wasted baking coils (and possibly melting the coating and making a short) for no good reason ( which causes global warming according to alarmists (which is all bunk)),  you could have bought at least 2  windmaster 400 watt windmaster turbines  that come complete with  a plug in type grid tie inverter,  and a built in charge contoller and powerfull charger.  All you would have had to do is stick them up in the wind (not on top of your roof) and bought a few batteries for your battery bank.
You could have then bought a new large screen TV and sat down and enjoyed watching it with the free power the windmaster provides.
Or you could have built your own windmills from scratch like we do  with the benefit of not having to make the same mistakes we did. and saved even more money.
Everything you needed to know can be found here:
http://www.scoraigwind.com/books/
kadora
Hi all
What about this generator which generates
electricity on rotor as well on as on stator.
magnacoaster
ok i have a question what is the speed this unit needs to run at ?
what is the mass weight ?
whats the voltage and amps it produces ?
whats the clog factor ?
do u have a website where i can see more about this ?
magnacoaster
wattsup
@MC
Like the fact that you chucked the alternator and you added an inertia wheell. You should try and make some real measurements by putting your amp meter through the battery + and give the readings on what's going out of the battery - verus what is being loaded on your generator side.
I am doing tests along these lines also although a totally different approach.
Question, you are using the alternator recitifier, but are you also using the original capacitor in place, or just the rectifier? Also, where are you sending your rectifier ground.
