new magnetic motor goes 2000 rpm without load 1000 rpm with load
Started by magnacoaster, March 09, 2007, 01:37:35 AM
hartiberlin
Quote from: magnacoaster on May 02, 2007, 08:50:42 PM
5 amps of pull still on the plus side
What do you mean exactly by this ?
Do you power all from one single 12 Volts car battery
and the battery is charged by 5 amps, so
the current from the battery is negative all in all,
so just only going back to the battery  ?
Or where do you power your motor from ?
Many thanks.
Regards, Stefan.
magnacoaster
i added a air pump into the loop infromt of the meter that shows power  out to the battery it can pull as high as 10 amps under load as i loaded it up i still got a positive feed to the battery as well as no slowdown in the motor
magnacoaster
You should try and make some real measurements by putting your amp meter through the battery + and give the readings on what's going out of the battery - verus what is being loaded on your generator side.
i have it setup so that it tells whats going in or out to the battery
battery - amp meter - motor + gen
Question, you are using the alternator recitifier, yes its mounted on the plywood
but are you also using the original capacitor
no we did not use this peice
Also, where are you sending your rectifier ground.
we have it isolated off the case with the wireing going to everything due to the em feilds you cannot use a case as ground as thre case its self will need to be grounded as to not charge up positive as the unit runs right now we have wheels on the case to isolate it off the floor as well as i have shoes on so i dont get a shock !
hartiberlin
magnacoaster,
I have problems understanding your setup:
1. Can you confirm, that you drive the motor with the same battery, that
your generator charges ?
2. Is the current coming out of the battery positive or negative ?
( So to speak , do you discharge or recharge the battery all the time,
when the unit runs ?)(if you just use one battery to power it all..and not 2 batteries)
Many thanks.
Stefan.
MeggerMan
Hi Magnacoaster,
Well done, I like the setup!
Are you saying there is 5 amps charge going back into the battery?
Could you find a smaller scale ammeter, say 10 Amps FSD as 60Amps leaves little resolution at the low end, or better still use a clamp ammeter.
Could you set it up as self running from a large 50v capacitor with no battery?
Just apply 12v supply to get it started.
Have you looked at using a solid state relay in place of the points or is the spark from the points critical to this working?
Rob
