new magnetic motor goes 2000 rpm without load 1000 rpm with load
Started by magnacoaster, March 09, 2007, 01:37:35 AM
magnacoaster
ok we have done more testing and have a new plan as of right now
input voltage to motor
12 vdc @ 1.5 amps
output from motor circuit
200 vac @ 2.5 amps
this gives us a  2700 % increase
we have reached unity
Ergo
I cannot belive anything of this.
Your statements clearly show faulty measurements.
You haven't really shown how you have performed you measurements nor have you measured
the input vs output voltage and current waveforms on a oscilloscope neither have you used certified instruments.
This clearly show that you haven't got a clue how electrical measurements are made.
Do you really belive that you have 2700% more output than input whithout questioning your own results without
any doubt or asked for professional certification? Then you are not fit to belong in this forum.
Basic Rules:
1: Don't make judgements yourselves on your results. Let professionals judge them.
2: Show exactly how you made your measurements in every little detail. Unless this is made your reports stink.
3: You should really take some lessons in electrical physics in how to make correct measurements and how to present them.
4: Most important. Make a self runner capable of doing some heavy work besides being a self runner. Show professionals your setup.
magnacoaster
i did not do my own measurements  we had it done by the university
his instraments were certified and we checked them before and after
well i seem to be the one who has done this and he agreed (prof) with me there was 12 vdc @ 1.5 amps in
and 200 vac @ 2.5 out as we need to have a way to make sure if the battery explodes it can be contained
as well as we need to do more testing to see how to get the most from the voltage
it was running @ 5 nano seconds betweeen waves this was fast power
Do you really belive that you have 2700% more output than input whithout questioning your own results without any doubt or asked for professional certification?
we will be going back within a few weeks as we all need time to digest what we have found as well as to get a handle on a way to slow the wave down and convert the power to useable DC
you are mister grumpy i see
Basic Rules:
did that
i will be doing this
why so they can teach me why it would never work (i have changed a few text books)
with a change in the windings and some parts we can get 100 amps @ 200 acv out and only put in 12 volts can you do it ?
wattsup
@Ergo
Relax will yeh already. No need to blast your horn. MC has been working very hard on his device(s) for months and months now and is showing it here and deserves some recognition. What he made did not materialize out of thin air.
Look at his previous set-up. That small motor on the right is turning that heavy inertia wheel in the center that is turning a chain gear coupled to his generator. The gears are I'd say 3:1 (3 turns of prime mover to 1 turn of generator). The 3:1 ratio matched to the inertia wheel produces alot of energy onto the generator. It seems he is also using a switching system to reduce BEMF on the generator but I could be wrong. Alot of this is Tesla. Everything is slim and not much room for wasted energy as heat developed in a standard generator. The only waste will be the chain gears friction. I don't see any capacitor(s) that could help in capturing BEMF.
@MC
You said "we have reached unity".
That's overunity if you ask me.
Good work man. It must have taken hours and days just to balance those wheels, let alone work your components into them. Fantastic work indeed. A true creator and great precision.
Please describe to us your new set-up or a photo and if possible try to explain how the university was measuring your results. Did they make a block diagram of the set-up and show where and how the measurements were made? See my previous post above.
I saw your other Youtubes, Good work. I know you are excited as we can sense your very exuberant attitude. Keep your good spirit.
A good proof is using a battery, showing that power never goes down and lighting up x watts of light bulbs showing voltage and amperage for x hours. This is a winner. Even better is looping the ouput power back to the prime mover off of a small 12V-4A battery while llighting up some bulbs. The smaller the battery, the better is the proof. Or even looping straight if the system can cut it. You may need an small AC//DC transformer to do this since the out/in voltages may not concur.
Ergo
Sorry but I'd really like some proof this time instead of just hearing the same story over and over
from some guy here that reports OU and then there is silence when we ask for validation.
And 2700% OU sound just to good to be true, and so far OU has never been true when tested for real.
I encourage you Magnacoaster to really prove your setup with real data and documents on your design
so it can be replicated and verified by other members at this forum of Overunity.
If you indeed have got "real" overunity then I'm really sorry for flaming you.
In this case you should have the Nobelprise and congratulations from the whole wide world.
