new magnetic motor goes 2000 rpm without load 1000 rpm with load
Started by magnacoaster, March 09, 2007, 01:37:35 AM
AbbaRue
I always used to say the real test of a true OU device is to have it run by itself for longer then is possible with the
amount of power fed into it to get it working.
But I have come to realize that it's possible that a true OU device may not be able to run itself because of laws
that conflict between input and output. (That's the best way I know how to put it).
SO I came up with a solution to this type of problem.
Build 2 copies and have the output from the one run the second one and then have the second one run the first.
I can see conditions that would make this the only way to do it.
Also building 2 working units will prove it can be duplicated.
I mention this because I don't trust any measuring devices no mater how accurate they claim to be.
The only sure test of OU is to have a closed system that once started requires no additional input.
The only exception would be a device that clearly puts out far more then is put in.
Like having a device run by a couple of AA batteries powering a 1000 Watt baseboard heater.
From what I have seen on these videos, if this device really works you should be able to connect 10 AA batteries to it and
use it to run that drill and the jigsaw.  Unless you cut the video, it showed the system running the drill as soon as you started it.
It would be almost impossible that the battery could have recharged that fast to run the drill so the device must have been running it.
So this device could very easily run the drill and jigsaw after being started by 10 AA rechargeable batteries.
And you wouldn't have to worry about blowing anything up, the rechargeable batteries would work just like the dead car battery.
I understand how using capacitors wouldn't work, because caps. don't regulate voltage.
They would just keep charging to a higher voltage until they match the voltage output of the circuit.
But a battery can only be charged to the voltage it is designed for, so it acts as a voltage regulator.
Also a caps. voltage drops continuously as you draw power from it, but a battery maintains it's voltage for some time.
MagnaTruth
Hi Richard.
This is Jo here. Not sure who the Ben Waballs dude is, but glad you remember me in any event.
For all of you on the outside, I am the copyright holder, cameraman and occasional commentator on the now famous video that shows the old magnacoaster unit running using a "dead" battery.
I have asked Mr. Willis to remove the video from youtube and stop using it as a marketing tool, and he has ignored my request.
Mr. Willis is aware of the fact that this video proves nothing, as others in this thread have documented. He has been repeatedly advised of the fact that no conclusions can be made from this "test".
While I wish Mr. Willis well, and hope that he succeeds in his quest for O/U, I must question why he must post this video from last year when he is trying to prove the validity of his current system.
Perhaps it is because his most recent post, which "demonstrates" his system, ends after about 20 minutes when the 11 lightbulbs that someone else counted go dark and the inverter appears to sound its "low battery" alarm.
Oddly enough, this is roughly the length of time that a charged car battery will power such a load.
These are the videos uploaded 3 weeks ago, and he may edit out that portion now as it may hurt business, but I have copies if anyone wants to see them unedited.
Over unity power generation is a reality, and I have seen it. But not on the magnacoaster videos.
Proof of O/U means accurately measuring real power in and real power out, not phantom power.
Perhaps you can show us something more worthy of your talents.
Good luck.
PS Richard, thank you for your "concern" about my personal life, but please keep this discussion on topic.
Quote from: magnacoaster on March 26, 2008, 06:44:18 PM
today i have spoken with the govenment here in canada we are now a green light to use the solar cell as the input energy this means we can get grid units out and the end user can get .042 per kwh as for the green show we are in talks with them now as well as a EV project.
Ben Waballs  how is vancouver ?
you wanted so bad to move there all the time you were here i hope now that got your wish it made you happy !
i know i miss having some one get me a coffee every day but hey i can go to tims now myself.
are you living with your folks still ? or that cool little hot artist chick that you spent xmas with ?
judy and andrew are they still in your life ?  and did you ever get your cats from judy ?
i know you were hatching a plan to have some one catnap them did it all work out ?
Richard
kensiko
Hello MagnaTruth,
So you are saying that his system doesn't work, isn't it? But you also say you saw O/U power generation, but where? With Richard's system?
b0rg13
the proof has been there all along for this device, no real video, no one is allowd to go check it out with meters and stuff,dosent want to open source it, but wants a CRAP load of money, its been screaming scam from the begining. ::)
if you want to get out of the rat race,you have to let go of the cheese.
MagnaTruth
I would love for Richard's system to achieve what he believes to be its potential.
I have seen O/U but not from Richard's systems.
The  video was my first exposure to such systems.
I have a much higher threshold of proof today.
Quote from: kensiko on April 02, 2008, 02:36:30 PM
Hello MagnaTruth,
