New magnet motor/full rotation/no electricity-just posted!
Started by Bruce_TPU, April 17, 2007, 12:04:17 AM
Paul-R
Disclosing an invention with just a video is a waste of time. Anyone can
fake a video. Do people believe that Alderon was actually blown up?
It is futile to spend more than a passing moment on technology that
is not accompanied by drawings and technical explanation.
What is the motive of not providing these docs?
Paul.
kidsicu2
hey
It is poor quality video granted. It does'nt improve in any of three I watched.
Of the critiques of this project I've read so far I can say that there are several points to address.
There is a piece of sheet aluminium that nearly covers the table. The aluminium has a painted on design covering it. It was probably used to stop controversy regarding a strong magnetic field produced under the floor or table effecting/causing the rotation observed. That's one of the reasons the camera was panned under the table.
The black box is a large computer minifan. You see it in all three videos. It could be powered but, would'nt the speed be much greater? Most of them I've seen are high-speed fans. In the first video you can tell that's what it is. The purpose is to have a stable turntable with good bearings. It's a great idea. Best of all, they're cheap and easily available.
There is a ring of small, cylinder shaped (I would guess magnets) objects around the entire bowl rim. I see one visable larger disk (magnet) on the rim as well. The bowl was to hold the (magnets) in that circular shape. I would suggest that the second video shows the failure of the v-gate approach. The third video is the progression using most prior components.
The backbrush just makes a good counterbalanced arm to set the magnets on that ride above the rim and ring of magnets.
I would say that there is considerable timespan between the making of the second and third videos. I would say that the posting on Utube was long after they did this.
ds yin/yang
kidsicu2
sorry I forgot to say its possible we were lucky to have even seen this. this was a very low budget project. good thing they even had a video camera.
Someone tried real hard not to give MIB clues. Doubt its faked but, is possible.
speed would be increased by porportioning ring magnets to arm magnets better. Would also gain by attaching a shaft through the arm. bearings on the shaft ends. precisely balancing arm, ie. magnet and counterbalance.
may also be benefits to closer ring/ arm tolerances. possible additions of arms. magnets on both ends.
I really believe that if people always act as you want them to it would be a perfect world.
ds yin/yang
