Downloadable Pic to help UNDERSTAND!
Started by Bruce_TPU, April 23, 2007, 09:44:09 PM
giantkiller
Quote from: turbosetch on April 23, 2007, 11:11:27 PM
sure you have seen this but look at the SM coil close up. Some thing look familar?
You mean to tell me I got this on my desktop also?
--giantkiller. Geez!
Bruce_TPU
Grumpy
S)omething H)appens I)n T)ime
Time is where electricity and magnetism begin.
        -Frank Edwards
otto
Hello all,
@Bruce
The picture is WRONG!!
No questions, please.
Just trust me.
Otto
