No-One knows how it works!
Started by kokomoj0, April 29, 2007, 08:10:56 AM
gyulasun
Quote from: kokomoj0 on April 29, 2007, 02:53:05 PM
Hello kokomoj0,
I would like to read your thoughts on the renerator if you do not mind. I find that circuit intriquing but so far I have not found any working replications on it. So at least maybe a theory of yours would do it.
Thanks
Gyula
Each toroid has 2 coils:
For lack of a better term:  A reverser to clamp the magnetic field and a secondary for the pulse output.
Then by using 2 coils you can tap a trigger pulse from the output of the opposite coil to trigger the collapse in a flip flop action.
Set it up for resonance to maximize the power out and it should generate power quite well.
The coil on either side of the magnet is wound so when it gets a trigger pulse it momentarily reduces the field of the magnet then when the pulse goes to zero the magnet feild goes back thus a generator output.
The secondary is wound so that the flux is in series with the magnet.
Personally I plan to use a switching device for the trigger and pump a square wave into it rather than a sine as it should be more effective.  Then just connect the outputs together in parralell for a full wave output.
Now if SM was using this design where it pulls its power off of the magnets i can see it working very easily.   However the approach that is being taken on it from what I have seen so far leaves me empty inside.
Here is a pic of it
Hi kokomoj0,
Thanks for your answer but  unfortunately, I have not been "cleverer" by it than I was, sorry to say this.  This topic was dealt with in this Forum last year, what is more, an updated circuit schematics was shown too,  I do not know if you are aware of that?
See these link here
http://www.overunity.com/index.php/topic,712.msg16680.html#msg16680
http://www.overunity.com/index.php/topic,712.msg17111.html#msg17111
  (quote from lynx2000nl):
The energy collected to use and to fire up the 2nd circuit is the energy produced by the KICK of the magnetic field stabelising after the actuator pulse was given. As we all know, a magnet distributes his field lightnig fast to the surrounding it is. So after the actuator pulse was given, the magnetic field instantaniously returns, giving us the KICK !
My main problem with this explanation is that the input power you pump into the actuator coil is able to disturb the permanent magnet's field to an amount equal (or rather less due to losses) to the energy the permanent magnet is able to return through induction into the coils. How can you receive more output from this process?  Can you explain?
Thanks
Gyula
devilzangel
Quote from: Mannix on April 30, 2007, 05:02:19 AM
"Argue for your limitations and you get to keep them"
Richard Bach
hello Mannix
nice quote, here are two more
"The man who never alters his opinions is like standing water, and breeds reptiles of the mind."
"A truth that's told with bad intent beats all the lies you can invent."
- William Blake
it was a simple speculation, a more simple answer would have sufficed.
devilzangel
otto
Hello all,
did you ever think about a TPU as 2 tornados (rotational magnetic fields) rotating in opposite directions?? 1 Tornado in CW direction and the other in CCW direction.
Otto
Moab
Grumpy
or two in one direction and one in the other direction
        -Frank Edwards
