prove the thing
Started by TheCell, May 07, 2007, 11:36:45 AM
TheCell
Has anyone proven (not so long ago), whether the efficiency exceeds 100%?
There is no doubt, that a electronic pulse device will lead to a higher gas output.
And a vacuum may enhance the exposion of HHO too.
But nobody believes you, if you do not prove the thing. If it should show a political effect, it must be explained in such a way that the effect is obvious.
And it should'nt be explained in a scientific way, because then only scientists will understand you , but they won't agree because you damage their intellectual property.
Heat a glas of water with the same ammount of voltage and amps you put in the electronic device, and heat anonther glas of water with burning the HHO you get from the cell.
If the temperature increase...
Good luck!
kokomoj0
Quote from: TheCell on May 07, 2007, 11:36:45 AM
If you find out let me know!  The only things i know of that truly go over unity at least that i feel pretty comfortable that are real is the the fusion reactor, (if you can operate it close enough to the sweet spot), and these magnet motor style generators.
That does not say that there are not more, that is all i am aware of at this time.
There are lots of devices like radiant and solar of course are free power but i did not include those.
From my travels i wont rule out the tpu as they are doing some interesting things with is.
For hydrogen generation i have some skeptisizm in that although i have seen cars running on them the longest drive i have heard of so far was little 50 mile jaunts on a joe cell.
Its like we all know that an engine will run on hydrogen that is a given but lets see some new york to Los Angeles runs or something really practical and that i have not seen anywhere on the net.
That does not mean it cannot be done or is not worth it, with gas over 3 bucks a gallon, i do hope this pans out with hydrogen so even a 50% reduction in gas useage would be worth a unit installation.
Maybe one of these guys out here has some good data that i have missed to share.
