New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
korinsj
Hi all,
Sorry my english, but I have one question.
Any one knows how Bob's gravity wheel works (less more).
Why? Because in my project of gravity wheel I have only 2 mass and some toth gears. No springs, etc.
But my project is very very close to Bob's machine.
I will build my gravity wheel in next week - so, I verify my theory in practice.
Regards,
  SM
helmut
Quote from: korinsj on December 30, 2007, 09:13:27 AM
Hi all,
Regards,
  SM
Hello Korinsj
I guess at the time nobody knows exactly how it works. Bob told me ,that the rejektion works mechanic way.
In the German Sektion is a patentet wheel exposed.
Perhaps you can use some idea.At least it is a proof  that many People try to use Gravity to drive a wheel.
http://www.overunity.com/index.php/topic,3821.0/topicseen.html
If you have Questions because of Germen Language,dont hesitate to ask.
But how do you go to handle your Work ?
I would like you to Open Source your plans and provide us with Pics and
Video at a given time.So that a Replikation can be done, as soon as possible.
Or at least a sketch.
Good succsess
helmut
WalterSingletary
Bob updated his website. He tells in more detail how his machine works he said:  [I have 1 drive sprocket to machine and install on the generator, and then I have Free Power]. end : at the end of his update
hartiberlin
Here are the details posted:
http://www.newsourceofenergy.com/Information.html
The unit works by raising the weight up to the top at the 12:00 o clock position and the lower weight follows as they are connected. A cam mechanism picks up the weight in the center of the wheel and raises them up approximately 4". After the cam, the actuator arm brings it the rest of the way. (8").  Remember the weights are joined so they have only 1/2 the distance of the total travel before there is no resistance. (12" on a 24" stroke).
The force of the weights turning now push both the weights out to the end.
The first two inches are the most difficult, so the closer they get to the center position, the weights balance out. as they pass the balance point (12") they go out to the end by them self and need a sizable cushion to stop them.
Remember the trick is that the weights are joined and the resistance is lessened to 0 as they reach the halfway point.
To stop the weights from impacting, I used a set of springs and two 25" air cylinders to absorb the shock of the weights as they reached the end.
I hope this helps.  [I have 1 drive sprocket to machine and I have [Free Power].
I thought it would work differently.
I did not know,that both weights are joined.
This way he is wasting power.
If he would only use one weight tobang against the peripherie and
use this impact energy to lift the other weight,
it would save him a lot of energy which could then be convered to
additional output power,as it would rotate faster then.
Regards,Stefan.
TheOne
Its supposed to work with a compressed air engine and he dont talk about it so what he is talked about is not really the true device.
Its like 2% of the device, nothing is explained in detail.
