HOW to use Radio Frequency as Catalyst!!!! TPU in Water!! Patent Here-->
Started by Bruce_TPU, May 21, 2007, 11:43:05 PM
Bruce_TPU
Hi Resin Rat,
From what I understand of this, (1) day reading,  is that every metal has a moleculer frequency.  The patent says that these numbers are readily available.
Next, you take your RF signal generator and set it to that frequency and put it into the solution according to the patent.
The solution "feels" the catalyst.  If it had a brain it would be tricked into thinking it is seeing that particular metal.
My first thought is KOH in water and Aluminum.  Replace the Aluminum with the molecular resonant frequency of the Aluminum metal and you have the KOH water mixture thinking you just put in AL.  And here comes Hydrogen!!  Can you say,"unbelievable!"  Where has this tech been?!
Thank you for your time,
Bruce
hanker886
kokomoj0
Quote from: lancaIV on May 22, 2007, 10:32:56 AM
How to use resonance to split water:
http://v3.espacenet.com/textdoc?DB=EPODOC&IDX=DE4238952&F=0
Received Patent-right !
But invented 1982: 2007, now free process technology !
S
  dL
thought i woudl just post it :)
Abstract of DE4238952
In resonance-based generation of H2 and O2 from water, using a hypersonic generator of suitable frequency, the resonance frequency (fO) can be that corresp. to the distance (d) between the nucleus of the O atoms and its outer electron shell or the proton. fO can be calculated approx. from the formula: fO = c/(pi.d), where c= the speed of sound in water and pi= the Ludolf's no). USE/ADVANTAGE - The H2 can be used as fuel in power stations or in hydrogenation (hardening fat), synthesis of petrol, MeOH and NH3, redn in metallurgy, in welding etc. The O2 can also be used for technical and other purposes. The overall efficiency of the process is much higher than usual and the process is more friendly to the environment.
Bruce_TPU
@ hanker
Unknown!
Time to get some links on building a RF signal generator.  Pese also know how to do this I think>  A Good readable schematic would be a good find, guys.
Bruce
keithturtle
Y'all might be lookin' fer awile to find the plans- these frequencies are in the gigahertz range, or so I was told by a physics prof.   The harmonics do the deed of splitting, but once you get past the third harmonic, the effect is so weak it won't do much good.  Might as well just buy a sig gen that can hit the high notes, uh huh, and see what happens there.
Surely some hack out there has done this already; try and find his thesis and build offa that.
Keith
Soli Deo Gloria
