HOW to use Radio Frequency as Catalyst!!!! TPU in Water!! Patent Here-->
Started by Bruce_TPU, May 21, 2007, 11:43:05 PM
Bruce_TPU
@ dutchy
you said, "(a catalyst that isn't being used up to be more specific)."
Please cut and paste the part of the patent that says that.
If not, it is an assumption which may or may not be true.
We will know when we start to experiment.
Thank you for your time,
Bruce
dutchy1966
Quote from: btentzer on May 23, 2007, 08:17:40 AM
@ dutchy
Bruce
Bruce,
It even says that the catalyst has to be inert .....
See the attached picture.
Robert
Bruce_TPU
@ Dutchy
That is all I needed!   ;)
I have been consumed in TPU land and have had not time to really study the patent yet.  It will mimic platinum.  I am not too familiar with catalyst, I am a pump in the amps and break the water!  LOL
So we need one of you chemist types to step in here and come up with a good experiment to use platinum for H or HHO production.
Bruce
keithturtle
About catalyst being "used up":
In the electrolysis reaction the water is broken down and off-gasses, and the catalyst (i.e. NaOH) remains in ever-increasing concentration till more water is added.  In resonance, so it is said, catalysts only get in the way.
And I cain't find what TPU means- what is it?  Total point unity?  I dunno- dumb newbie question...
Keith
Soli Deo Gloria
pese
 @btentzer
here you find the asked lesson to study.
use right link for "oscillator"
(more on my mail)
http://www.tpub.com/
http://www.tpub.com/content/neets/14181/index.htm  INDEX
http://www.tpub.com/content/neets/14181/css/14181_13.htm   1-1 CHAPTER 1 TUNED CIRCUITS LEARNING OBJECTIVES
http://www.tpub.com/content/neets/14181/css/14181_65.htm   CHAPTER 2 OSCILLATORS LEARNING OBJECTIVES
http://www.tpub.com/content/neets/14181/css/14181_103.htm  3-1 CHAPTER 3 WAVEFORMS AND WAVE GENERATORS LEARNING OBJECTIVES
http://www.tpub.com/content/neets/14181/css/14181_159.htm   4-1 CHAPTER 4   WAVE SHAPING LEARNING OBJECTIVES
http://www.tpub.com/content/neets/14181/css/14181_231.htm    Assignment Questions Information:
The text pages that you are to study are provided at the beginning of the assignment questions.
