Gigantic drinking birds
Started by hartiberlin, May 27, 2007, 01:30:10 PM
hartiberlin
25 Watts constant output will not be doable with smaller
sized versions, but you can use this bike light generator
unit to charge up lead acid batteries 24/7 all day /week /year
long:
http://video.google.com/videoplay?docid=6537266223222682967
It has the advantage, that it produces nice current and voltage spikes
which  charge up lead acid batteries nicely and fast.
Also it does not slow down much the drinking bird.
So it would be the perfect and cheap generator for the drinking bird !
For the evapourated water, you could design a water container reservoir,
which will put water automatically into the bird?s head water container,
if the water level would fall there.
E.G. something like a swimmer controlled valve.
If the water level falls, a valve will open and
the water from an upper reservoir can flow into the lower
bird?s head water reservoir.
Thus you only have to refill the upper water reservoir
maybe once each week with some water, so not much
maintainance needed.
The power output at charged up lead acid batteries should be
enough to at least run your laptop PC for a few hours per day
and maybe some 12 Volts LED lights.
Best regards, Stefan.
FreeEnergy
Quote from: FreeEnergy on August 27, 2007, 04:21:15 AM
if you make the ceiling high enough i don't think you will be needing to add water to the system. should be self sustaining :)
peace
what do you guys think?
Humbugger
Quote from: FreeEnergy on August 27, 2007, 05:09:17 AM
peace
Please explain how the ceiling height would effect the water usage.  I don't understand that.  Sorry!
lltfdaniel1
25 watts sound okay,if you play around with it, and add more generators you can get to 50 watts, just like adding multiple batterys in series,
you could make a 25 watt allways on light bulb,i would think that to be cool,you could tell scientists who think free energy is aload of bull , it, heh.
well,if you come up with something quite impressive with drinking birds i would be interested in buying it.
You could crank up the output to 100watts,see how much that would be with a bit of profit etc,
to me 100-200watts sound minimal enough for me, 25 watts for a always on lightblub,
even though i would be interested in buying a 25 watt fe drinking bird machine.
heh keep going.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
FreeEnergy
because the atmosphere  becomes saturated with water vapor and the bird stops. we want the vapor to stay away from the bird's bottom so it stays dry :) so rising the ceiling creates distance and vapor stays away from the bottom.
peace
