John Kanzius: saltwater can burn!
Started by majkl, May 27, 2007, 07:30:40 PM
jox
This is a post through Sterling D Allen to the kanzius_effect group
Hi Graham,
We address your question in the opening  of our coverage at
http://peswiki.com/index.php/Directory:John_Kanzius_Produces_Hydrogen_from_Salt_Water_Using_Radio_Waves
"While the phenomenon is interesting, it is not yet practical for energy generation. More energy is consumed by the radio frequency device than is produced for burning. Efficiency-wise, they are presently at around 76 percent of Faraday's theoretical limit."
Then under "Latest Developments"
June 06, 2007
John Kanzius write:
"Since it appears we now have now achieved more than unity, I am going to do an embargo on releasing all further information.
"Actually there are smart individuals who have posted on different web sited and actually have a pretty good idea of what is happening."
IronHead
For  John Kanzius
Install 2 stainless steel rod type electrodes inside of the tube  . Add  low  current about .01 amp DC at 20 volts to 30 volts to the  rods. The rods should be .15" apart This will induce a magnetic field in the tub.  Now you can cut back the power to the linear amplifier.Experiment with the numbers  you will see the outcome quickly.
Also your resonance will change some with these rods in place  . you will have to twist the knob abit.
And put that thing in a bomb box! Just in case the good the bad and the ugly happen .
EDITED        this is an easier and safer way.
dlwammo
New to site.  Been reading for last several days trying to absorb.
I know 13.56 MHz is for RFID use.  Patent mentions 13.56 MHz and 27.12 Mhz harmonic of this.
I'll keep on watchin'...
Don't mess with old farts... age and treachery will always overcome youth and skill!
jox
Hi Ironhead Your method appears similar to whats described in this patent
http://www.freepatentsonline.com/6217712.html
at the bottom in test example he quotes the frequency as 9.29Mhz magnetic resonance frequency of platinum at 1.05 watts that seems within the do able area of an experimenter. Is this still as dangerous?
IronHead
I believe it is ,but I do not know for sure . I  am in the 12 to 15ghz  and also 40 to 50ghz area now .
These frequencies all depend on the  water type and the apprentice itself. I have just  stated with a new type of chamber using Quartz instead of Pyrex . I have had no reactions lately as I am abit impaired at the moment. I hope to get back into this thing full throttle within the  next month.
I would treat all HF  RF Hydrogen experiments the same as you just do not know what is going to happen and it can happen in the blink of an eye.There  is very little gradient in these reactions ,next to none.
It is my belief  that a bomb box is required  for any and all experiments on this level .
