John Kanzius: saltwater can burn!
Started by majkl, May 27, 2007, 07:30:40 PM
dlwammo
jox
Have you tried using http://www.pat2pdf.org to look at patents online?
I'm new here, so I'm not sure if anyone else is using it.  It sure beats reading all of the "teasers" from www.freepatentsonline.com -  Just enter the patent number and it will spit out a pdf of the patent for you.
Also, great job IH!  Keep doin' what you're doin'....  I can't replicate anything here on this end, but that doesn't mean I can't learn anything either.  I will try not to post unless I just can't help myself.
Thanks.  This a great board guys!
Don't mess with old farts... age and treachery will always overcome youth and skill!
keithturtle
IronHead;
In yer suggestion to Kanzius, you mentioned a pair of rods 0.15" apart.  Are these concentric tubes, the outer one with an I D  0.300" larger than the inner's O D?
If parallel, are diameters the same?  Round, square?
Thanks,
Turtle
Soli Deo Gloria
IronHead
no ,two solid rods next to each other. A cylinder is much more tricky and must be cut to resonate in a particular range as the RF will absorb into the tube . This would require inner and outer transducer  more like what I am doing. A different game all together but still based in RF.
kukulcangod
Once I got lazy and heat up a cup of water in the  micro for a couple of minutes or less but what surprised me was that as soon as I put the stainless steel spoon in the liquid this started to boil up! no sugar no tea , just water and steel..... is this related to what Kanzius got? , Now for sure the setting has to be very precise because this doesn't hapen everytime or ever since  I just calculated by feeling when the water was ready
it always puzzled me this result but let it in the back of my mind of course......
Where can I learn more about high frequencies and harmonics with not to technical terms?
Thanks for the feedback.
Good luck to all.
d3adp00l
no, phase changing and molecular breakdown are very different things. what you did is similar to the freesing corna beers on youtube, or the explosion of steam i get from my coffe cup every morning when I put really hot water in it and shake it.
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
