Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
hartiberlin
Hi Ash,
just do a full wave rectification with  say 1000 uF high voltage cap at the output
and measure a DC load like a low ohm resistor or a toaster or a few inc. light bulbs
as the load in the range of 2000 to 3000 Watts.
So you can measure DC volts and DC amperage in the load.
Maybe add a few chokes and a few more caps for a better lowpass until you really have DC and
no ripple on the voltage.
Try to see, if the input then really only draws around 800 Watts.
Try to see, how the big wheel is working with the displacement of the weights !
Is there a big hose of water being moved out at the right side or
what kind of weights are these  exactly  ?
What is this red thing there moving out and in again ?
Thanks.
Regards, Stefan.
ashtweth_nihilisti
Quote from: tao on July 05, 2007, 09:40:58 PM
He says that he channels back 25% of the output energy and that this keeps the unit perpetually moving, ie. perpetual motion.
So the question is, If the alternator is run only via the gravity motor, like he says, what is that 25% of electrical energy used to do? Why does any electrical energy need to be cycled back?
Unless, he uses some of that energy to bypass a 'locking/sticky point' in his gravity motor.
Did he tell you anything about that Ashtweth?
Tao, sorry i missed this man, First stefan thanks Bro..ill put it past him.
now only as he wanted to show that % power out is being used to go back into the input, so showing what he has OU.
Yes he described some 'relay' concept' where one weight does some work and then its braked then another takes off, thats in his new fly wheel, he didn't go into much detail sorry. He is waiting to finish his final design i assume he will tell us then.
Ashtweth
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
hartiberlin
Hi Ash,
did you see his device live yet or only on the CD he gave you ?
Please try to visit him , take a video camera with you
and tape the inner workings of the big wheel
and gear wheels.
Many thanks.
hartiberlin
Ash,
is he in the new video still using 800 Watts
from the grid as the input power ?
I don?t see any input power cables ?
kames
I am attaching a screenshot from the Chas?s video. If you look carefully at the big wheel, there is a big red and probably heavy ring in the middle. During the entire video that ring remains in the same position, ie, further from the center on the right side and closer to the center on the left side. That is what creating a difference in gravitational force/momentum and keeps that big wheel rotating. How he did it I don?t know but this is absolutely obvious from the video.
Kames.
