Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
singerxyz
Quote from: acerzw on September 25, 2007, 10:40:55 PM
Singerxyz
Thanks for the confirmation that this works, I had posted on another thread regarding this possibility, it is good to hear that it works, it will simplify experimenting a great deal.
Acerzw
It also means that once the proper frequencies are found, they can be mass produced/replicated as easily sending an mp3!
singerxyz
Quote from: jack81 on September 26, 2007, 09:29:18 AM
Wait...
@acerzw & singerxyz:
are you shure that soundcards and/or final stages of audio amplifiers do arrive at the required frquencies?! If this thing works without any function generator but with an ordinary soundcard and heterodyning that would be great! With "Adobe Audition" I can generate just all the waveforms I want!
Yes, I'm sure. And as far as a volt meter goes, the results were better than the original signal!
I would like to see people posting frequencies as high quality mp3's for us all to play with.
Nice!
CTG Labs
Hi all,
I have replicated to my best ability the LMD/TEM test.  It can be seen here: http://www.ctglabs.com/TEM_LMD.htm
I have seen no excess power, but I can confirm heat appearing at the far end and not at the output end, etc, when in LMD mode.
I can also confirm signals in LMD are IN PHASE, not lagging!  This should mean more real power?!
It should be noted that JLNs test results appear in a computer simulation using microcap software!
Regards,
Dave.
z_p_e
Quote from: CTG Labs on September 26, 2007, 04:41:27 PM
Hi all,
Regards,
Dave.
JLN using a sim? Say it isn't so. I thought only PC Heros used sims. And he is showing ou? Impossible I say!
turbo
Hi all,
Regards,
Dave.
Hi Dave :)
Why is that end inductor getting so hot while there is almost no current flowing thrue it?
This is a bit weird because it doesn't fit the classical model...
Are you splitting the positive ? :)
Did you use a neon bulb to see that it lites up on one wire?
I always have a hard time with the henry stuff.
Marco.
