Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
otto
Hello all,
@Dave
very nice work. I think it was also a lot of work to do to wind this coils,ha,ha.
@All
I wanted to make a picture of my perfect sine waves with a kick sitting on top of this waves but I cant. I cant because my sine waves are gone. They dont exist anymore!!!
When I started to work with my deflection coils I first connected  +12V from a power supply on 1 of my coils and on the other end of this coil I connected my pulses. I saw perfect sine waves with a kick on top of this sine waves. Yesterday I tried to do the same but no way to have sine waves. Hmmmm.....now I remember: Im working with 24V from the power supply. Maybe this is the reason.
I also wanted to remove the iron core from this coils but there is no way to do it. The outer coils are wound ARROUND this core. If I would remove the complete outer coils with the iron core and make new windings for the outer coils without the iron core....instead the iron use 2 other metals....an Aluminium alloy. Alloy because I earlier saw that a single metal doesnt work so good....remember my tests with metals for use as a collector...
Yesterday I tried my other deflection coils and had no sucess. After I disconnected this other coils I saw that there is a resistor connected in this coils. I hate resistors with coils!! They are heating up.
What now??
I will try to pulse my deflection system that didnt work. Just to see if every deflection system works in the same way.
The biggest problem with this deflection coils is that there is only 1 frequency mix that gives me my good results. If you fail this 1 frequency mix your results will be not soooo good.
Otto
Thaelin
   I fear you will run into problems with this direction. First of all the sound card will not have the best  DAC/ADC's in it. Hence the resolution will not be good enough to use for TPU work. Second trying to use an MP3 to send files is a waste. The compression will clip off the parts that the human ear cant hear. Gone for good. A wave file would be needed there. Third to generate that kind of tones, you would need high end synth machines. Just my thoughts here. I have the progs for the pc and they work, somewhat.
thaelin
Quote from: singerxyz on September 26, 2007, 09:47:54 AM
Quote from: acerzw on September 25, 2007, 10:40:55 PM
Singerxyz
Thanks for the confirmation that this works, I had posted on another thread regarding this possibility, it is good to hear that it works, it will simplify experimenting a great deal.
Acerzw
It also means that once the proper frequencies are found, they can be mass produced/replicated as easily sending an mp3!
ronotte
@Dave,
It is really a pleasure to see you back in the troubled  'experimenter's land'.
WELL DONE & DOCUMENTED
We are all struggling to find the correct way to improve the ECD and your thought is certanly wellcome . The experience gained till now is high but still not enough to reach the overunity target. For example my Caduceus coil test led to very near COP=1 situation with a minimal setup.
The duplication of ECD/run-away situation seems up to now very difficult to reach even if yesterday I experienced a fatal incident to my Wavetek function generator. The fact is that I were testing special coils in a controlled environment...but somehow it happened. So now I'll try to repair it!
Ciao
Roberto
Grumpy
        -Frank Edwards
otto
Hello all,
as you maybe know Im pulsing my deflection coils only with square waves becaus I have NO sine waves on my oscillators.
The inner 2 coils of this system are connected to a 100W bulb and the outer coils are not connected to the bulb. Only 1 end is connected to the 3 frequencies and on the other end was my scope.
The signals you see are a little over 600V. This signals are already a mix of 2 frequencies.
Otto
