Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
otto
Hello all,
@Megla
Croatia, and to answer your post a few days ago: THE ECD IS NOT A TRICK. Maybe you think a "little green guy" pushes the electrons in my ECD??
Otto
ronotte
Hi Dave,
I really wish I had the opportunity to have a discussion with you at time when I played with my 2MAGCLASH-TPU. At that time I went well forward with said project harnessing for the first time (at least for me) the power coming from NMR resonance. The project was so simple! but apparently none tried to use & enhance the NMR process to gain OU just as you descripted so well within c_s_s_p group. It would have been worty & useful for both to know if you also did the same tests before or after writing your highly appreciated paper on fateback site.
I persisted for some time with the 2magclash project accumulating lot of quite well documented evidence but then, aftyer seeing that apparently few was interested, and mainly because i did not obtained after reiterated efforts any OU, I considered it only a play ground. After all taking out about 60W of power from NMR and using only some copper wire for itself has been anyway an unforgettable experience. Actually I still have the device I built.
Not succeeding into making a group for exchanging experiences and toughts has been a major factor for stopping the development. So now I've read and re-read many time what you are writing about NMR and platonic solids....and I wish you did it before! ...why not?
Again I never used CHORDS and so I struggling to know everythingh about them.
I wonder if there are upgradings about your experiences & writings about this subject.
Roberto
acerzw
Quote from: acerzw on December 22, 2007, 06:49:27 AM
@sparks 'energy form' got me thinking....
@all
I have a radical solid-state vacuum energy device idea which I want to run past you..... it is as usual with me a bit far out... but here goes...
To fully understand this idea I recommend you read this great page, a link to which I posted on page 39...
http://www.timstouse.com/EarthChanges/ScienceOneness/chapter13.htm
You could search google video for "cymatics" too, an example:
http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=5860842
In summary a two or three dimensional form is created when a standing wave (or moving wave with the right frequencies) is contained or restricted by a barrier which is impermeable to it but reflects it. Adjusting the frequency of the wave source and the size of the barrier changes the shape created, so:
Now suppose we create a metal/wire sphere, which might need to be electromagnetically charged. Now we place in the centre of this sphere a perfect electromagnetic energy broadcast source perhaps a small metallic sphere, such that it can radiate electromagnetic pulses outward in an almost perfect spherical wave.
Using the principles of cymatics, we then tune the electromagnetic pulses from our central source so that they create a cymatic energy form inside the wire/metal sphere. This form of our choosing will have either node points (in the case of platonic solid forms) or points of high energy concentration (in the case of other patterns). Now I suspect if the pressure/stress created in the ether at these points was high enough then a specially designed energy capture probe placed at these points, by inserting through the spherical metal sphere/mesh, might have a reaction caused in it that allows it to extract vacuum energy. If the device was a metal sphere perhaps the probes could just be round plates built into its walls at the node intervals. (There might be anti-nodes to if Russell is correct that could be tapped too, or perhaps the potential between nodes and anti-nodes could be used?)
The design of the probe would probably have to include severals parts/elements organised in a specific way in order to create a potential which the vacuum energy under the extreme stresses would be obliged to fill in order to attempt to bring the system back into equilibrium. This might mean pulsing the probes with a field of some type.
In order to make the containment barrier effective it might need to be charged or pulsed in some way... as it needs to reflect the contained pulses... not absorb them...
This is kind of based on Russell and Keeley, but particularly Schauberger, who showed a very high pressure energy vortex has a central hi-stress nodal point at the center which can tap vacuum energy... The shape of the device also reminds me of Tesla's Wardenclyffe tower...
The tuning would have to be very specific in terms of the size of the sphere, the frequencies and materials used. But it seems logical to me that it would work. Plus depending on the Cymatic form created due to the frequencies used the number of nodes/high energy points can be increased (made very dense indeed) and thus the number of probes, increasing the output. Indeed if the correct structure design/material were used it might be possible to replace the probes with an internal three dimensional energy collection mesh made of wire in order to be able to tap internal high energy/stress points within the form, if the more complex forms were used... we must remember here that materials can be invisible to waves of certain frequencies so the right material could support a grid of collection devices yet not interfere with the wave energy.
This basic theory is semi-supported by the comment I have seen on other energy forums that the "Joe Cell" energy device is designed around a wave form, its concentric rings coincide with a wave form as shown in the Walter Russel energy diagram at the end of this post.
I do not think the input energy's would necessarily need to be high, just the frequencies, so the input output ratio might be pretty good. I can think of many variations of this idea, it seems to me to be a potentially important key...
Waves are three dimensional, we only use two dimensions in our current devices so are wasting tons of energy, we need to go 3D! Surely a "Joe Cell" of concentric spheres would be more efficient than the current design.  8)
If the sphere were filled with hydrogen, helium or water using the right frequency (possibly of sound) there might be enough energy at the high stress points to disassociate the molecules and produce excess heat (as described in my page 39 post). If the metal sphere of the liquid/gas is placed in a pressurised compartment filled with water the heat from the sphere would heat the water producing steam which could run a turbine to produce more energy. The liquid/gas in the internal sphere would need to be pumped through it and cooled at a later stage which would cause it to recombine and then it could be passed through the system again... a closed system. The energy produced on the output could be used to power the internal frequency generator thus creating a self-running system. This reactor design is documented in "Occult Ether Physics" by William Lyne. Can we say super efficient cold fusion reactor!
Someone, Tesla? probably did this already? A Cymatic Energy Form Generator...
A
This talk of Platonic Solids reminds me of the above post, something to try...
A
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
otto
weri812
HELLO ALL
HAVE A HAPPY NEW YEAR !!!!!!!!!!  ;D ;D ;D ;D
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
