Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
Grumpy
Quote from: sparks on August 11, 2009, 08:56:10 AM
More like squeezing a hoola hoop.  With the phasing of the squeeze at different points around the hoop we start to get like a moving magnetic field compression within the core.
Quote from: rotaryfcg on August 11, 2009, 02:36:15 AM
could it be a lot easier than that?could it be like cyclically compressing the flux that surround the conductive core(copper or not)?
could these pulses perform this feat?
http://www.overunity.com/index.php?topic=7377.msg189450#msg189450
        -Frank Edwards
sparks
The pulses I would imagine would have to be such that they result in maximum compression without oversaturation.  Then there still remains the problem of capacitance.  The compressing coils would have to be tuned for both inductance and capacitance so that maximum core compression results without loosing energy coupling capacitively to the field.
Otto noted something interesting way back that the currents inside the collector windings would induce a magnetic field that ultimately would create a counteremf to oppose the input voltage.  With such a high ramp and short duty the pulse is long gone before any counteremf is generated by the load current.  So now your getting around lenz. With the counteremf with nothing to do but create eddy currents is it any wonder that the unit overheats.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
forest
My question is :
assume you have created nice rotating magnetic field around Tesla like ring transformer, then you find a wav to create kicks
DO KICKS ROTATE WITH MAGNETIC FIELD ?
giantkiller
Do faster, shorter waves travel across a slower moving brook? Why, yes, they do. Can you temporarily stop the flow of a brook by dropping a larger rock in the middle? Why, yes, you can. We have all played in the creek before and noticed these things.
Time to take a second look.
I can put this another way. The first time I saw a live mass coronal ejection I noticed the span of 4 million miles took 20 seconds to leap. I saw fast fire. Amazing. But how can fire travel at that speed? It can't. What we see is the magnetic field already established burning in place. The fire doesn't travel that far from the sun but burns at the place when the magnetic field interfacing enters into a visible range. Think about that. The 'electric universe' youtube shows the suns fire going down into a sun spot. The center of the sun has no visible premise to us. It seems entirely magnetic like a black hole with a spherical boundary encompassing it, what we call the sun. In the TPU we could call that current. Doesn't current get hot? Probably just the incorrect interfacing...
Quote from: forest on August 12, 2009, 10:30:17 AM
My question is :
Grumpy
Quote from: giantkiller on August 12, 2009, 11:28:06 AM
The general consensus is that the friction of the electrons causes the heat - more current = more heat.
a current that does not involve "particle friction" might not produce heat
        -Frank Edwards
