Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
mrd10
Hi All,
Quick post here, tonight in the lab with Cam, this is what we found out:-
-just having the bobbins connected, we were able to light the bulb much better without the collector coil,
In other words we removed the mobius top ring and the bottom ring all together, and with 12v@ 1 freq the bulb lit  brighter, than it did with the mobious ring.
We didnt even have it in tpu format, we actually put a straight piece of ferrite rod through the 3 bobbins, this made a difference as it should, without the ferrite, the bulb was dim.
So results are:-
-3 bobbins only, connected as per Ottos drawing, and doesn't have to be in tpu fashion.
-mosfets are key to bringing amperage down compared to power transistors
-Used 1 freq, bulb lit at 50%, just over 1 amp current draw.
-with 2 freq we got 3 amp draw @ 12volts and the bulb was at almost full brightness.
we figured we were getting about 70% efficiency, best to watch the movie.
-then we upped the voltage to 24volts @ same current draw, I believe it was 2 amps, it brilliantly lit the bulb and then not long after blew the mosfets. Note in video were using 12 volts and not 24volts, 24 was tried before we did video.
Kind Rgds,
Dom
tosky
The removing test result by Rich is conflict with Otto. Their setup may have a little difference. Otto should also test it and give detail data.
Mannix
The distance between the coils is critical...
Slow down an bit here.
Otto used plastic nuts and bolts on his way there ...tried moving up and down a bit?
The tuning does change a bit?
Keep going.... 2 freq ....
Im just saving Otto the trouble here!
but of course the design will change. Not sure that you have the base line yet.
Lindsay
Bruce_TPU
@Mrd 10
Question:  What was the bulb wattage?
Can you draw a circuit the way you had it wired for us?
It could be a different frequency in each collector (as SM stated, see my post above) and then where they join together, POW.
Cheers,
Bruce
Bruce_TPU
Did Cam use a scope and see the "conversion" process through the bobbins from square wave to sine wave?  Did he see the "seed" that Otto and Roberto reference in their .pdf
Did the process look the same as it did with the collectors attached?
Did he try adding more than one bulb at a time?  And why has no one put an amp meter between the output and the light bulb.  If they have I haven't seen that posted.  Or volts output for that matter.. ???
Cheers,
Bruce
