Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
chrisC
Dave:
If you stuck out 2 fingers and wind the coil clockwise over the fingers looping back towards yourself, that would be considered clockwise. Both primary and secondary are wound in phase. That's how I interpret this.
chrisC
gn0stik
ZPE, one thing I have been wondering, is if we were supposed to replace the mobius with a ferrite.
When we removed the mobius completely and did not replace it with anything, we could not get the bulbs to light much at all.
Rich
CTG Labs
Ok Rich,
I have had a long day at work!  If I wind a coil and end up with a pig tail which from one end of the coil goes over the top clockwise, if I now look at the other end of the coil, that pig tail now loops over counter clockwise over the top.  Are you saying yours goes in the same direction no matter which end you look at the coil from.
One of us is surely communicating from another dimension here?
D.
Bruce_TPU
@Everyone
I had watched Cam's lab last night until about 8pm CST.  and just now watched the video.  I feel frustrated for several reasons.  Rich hit on one of them, only one frequency was being used, in the video anyway, not three.  There was still no amp reading between the output and the bulb, either the fluorescent or the other.  It was said there was 1000 volts measured at the output with a bridge of High voltage.  What was the amperage?  It looked to be 1.5 amps input with one frequency @12 volts.  This is 18watts input.  But output were two bulbs, 1000 volts and no amp readings.  And this with only one frequency and no phase inversion (we should still put all of SM's clues into our experiments)  And it comes across as, "ho hum, no big deal, just another tesla coil.  Time to move on to something else."
Very frustrating.  My wire came in the mail, to finish my last control coil, Mobius One is on the launch pad.  Circuit will be built tomorrow with my partner, I hope.
@Otto and Roberto
Thank you both for your tenacity, and keep plugging along.  Keep us informed of any new findings or ideas.  We are with you guys.  Jason has built and is just getting going.  Rich is building, Marco is building, Lindsay is building. I am building.  Patience, perserverence, single mindedness, creativity and accurate testing.  Experimenting according to SM's words will yield results.   :)
Bruce
c0mster
Guess I forgot to mention I did try 3 frequencies, it seem to kill the effect. Who has used 3 frequencies?
2 Frequencies doubled the amp draw, sure the light was brighter.
Guess I also forgot to mention I did bridge the output <u see it sitting there in the movie> and mesured the amps or should I say ma which would barley read on a 1 amp meter. It was 1200v at .01 amps = 16 watts and I was driving it with 18 watts. Theres lots of volts there but no current. Guess I'll grab 3 more mosfets next week, put it back together and make a movie of the whole thing.
I want this to work just like everyone else so I'll give it another go.
Cam
